2016 yz450f rear wheel
7 replies to this topic
  • Stevemeist
Posted February 15, 2016 - 05:30 PM
Hello everyone! I got a question for someone that knows hub and bearing dimensions on the 2016 yz450f. The question is will any other year model rear wheel fit this bike? I know the 2014 and 2015 will, but I was wanting to find an older, cheaper wheel if possible to throw a paddle on to hit the dunes. Any input will be greatly appreciated. Thanks!
  • avlisj
Posted February 15, 2016 - 07:00 PM
I have a '14 and have found the same hub part number all the way back to '09. And if a'14-'15' fits a '16 you'd be in the same circle. Is same hub as Yz also, 450 has wider rim than 250 but same hub.
  • Monk
Posted February 15, 2016 - 07:02 PM
-09-current YZ450F will fit
-10-current YZ250F will fit
No 2t wheels will fit (22mm axle) or the FX wheels which supposedly have a 22mm axel also...
Edited by Monk, February 15, 2016 - 07:04 PM.
  • Stevemeist
Posted February 15, 2016 - 07:03 PM
Do by chance know if the axel is the same diameter on those models?
  • Monk
Posted February 15, 2016 - 07:05 PM
Axel is 25mm on the 09-16 YZ450F
Axel is 25mm on the 10-16 YZ250F
  • Stevemeist
Posted February 15, 2016 - 07:29 PM
Cool! Thanks you guys!
  • patrick2wd
Posted February 16, 2016 - 02:31 AM
My guess is that all the wheels will fit, at some modelyears one has to change the bearings,
I have a set of YZ wheels waithing to get into my still-to-buy 2016 WR......
Edited by patrick2wd, February 16, 2016 - 02:33 AM.
  • Super_Davee
Posted February 16, 2016 - 01:13 PM
Heres some info I received from a reputable vendor when searching for a set of motard wheels for my 16 WR. Hope this helps someone.
There's a few differences with the YZ/WR.
  • Wheels
    • 20mm front axle, 22mm rear for ALL WR and YZ up to 2008
    • 20mm fr, 25mm rr for YZ 2009-13
    • 22mm fr, 25mm rr for YZ 2014-16
  • Brakes
    • Rotor the same for all WR250F/450F and YZ250F/450F
    • Caliper the same for all WR and YZ up to 2007.
    • 2008-16 YZ caliper different
