Any one using carburator cleaner in gas tank ?
2 replies to this topic
  • humbertob
Posted March 10, 2002 - 07:34 PM
Does any body here are using some cleaner in the gas tank to keep the carburator clean.......? Mine is working very fine with no problems at all, but I need to maintain it at that point ! So can I use carburator cleaner in the gas tank.....? If so, what brand....?
Thanks to all ! :)
  • CRBrandon
Posted March 11, 2002 - 07:31 PM
You don't need it. Don't run it.
Your bike doesn't have injectors.
Get an in-line fuel filter and you will be fine.
D
  • MN_Kevin
Posted March 11, 2002 - 09:05 PM
You should VERY REGULARLY clean your accelerator pump housing. The 98/99's are VERY PRONE to dirt intrusion.
Carb cleaner won't remove silt from your carb.
Kevin
  • Hot  30 replies
  • Hot  50 replies
  • Hot  36 replies
  • 10 replies
