Oil change question
7 replies to this topic
  • DRockk
Posted February 13, 2016 - 01:45 PM
I have a rekluse exp 3.0 clutch in my 2014 yz450f and I just did an oil change assuming yamalube 10w-40 (manual spec) would be ok. I heard Rotella is better. Should I stick with yamalube?
  • Goforaride
Posted February 13, 2016 - 04:46 PM
$12 a gallon for Rotella and Rekluse actually suggests it. Can't go wrong. Just make sure you use the non synthetic white bottle.
Edited by Goforaride, February 13, 2016 - 04:48 PM.
  • DRockk
Posted February 13, 2016 - 05:52 PM
But how about the rest of the motor, is Rotella up to spec keeping the rest of the motor lubricated?
  • Monk
Posted February 13, 2016 - 05:55 PM
Rotella will work just fine...
  • RMK800
Posted February 13, 2016 - 06:36 PM
Rotella T6 meets the motorcycle JASO standard.
  • Goforaride
Posted February 13, 2016 - 08:32 PM
I've used only Rotella in my '14 since new. It was recommended by a well known atv engine builder in my area. Myself nor anyone he know has had an issue running it
  • BDubb106
Posted February 13, 2016 - 08:34 PM
If pro's can run it in their bikes... it will hold up just fine in ours.
  • DRockk
Posted February 14, 2016 - 04:20 PM
That's enough to convince me! Will try it out for sure just wanted someone with experience in theirs before I put it in mine.
  • 5 replies
  • Hot  30 replies
  • Hot  36 replies
