Crankcase dowels help! ASAP!
8 replies to this topic
  • bikebuilder42
Posted February 12, 2016 - 01:20 PM
What's up guys,
I went to bring my crankcases together and the one dowel on the left of the crank is not lining up with its hole however everything else does, what could be the problem??
  • DinoY
Posted February 12, 2016 - 02:03 PM
Why did you split your cases in the first place?
Did you have a gear problem?
If everything else is ok case might be crack.
Or dowel is jammed wrong
  • drtrcr400
Posted February 12, 2016 - 03:12 PM
A picture is worth a thousand words. Let's see it.
Edited by drtrcr400, February 12, 2016 - 03:12 PM.
Posted February 12, 2016 - 04:22 PM
What's up guys,
You don't have the dowel where it belongs.
  • bikebuilder42
Posted February 12, 2016 - 04:52 PM
I bought the YZ off craigslist & the motor was blown up, I end up getting a new set of cases for it as well as a new crank, piston and cylinder
Everything lines up except the bottom dowel all the way to the left
  • drtrcr400
Posted February 12, 2016 - 05:41 PM
Grey is right, one of those dowels does not belong where it is. Without knowing what year this is I can only provide general information. There is only a total of two dowels that align the center cases. They are supposed to be on near opposite sides of the case, not adjacent to each other as in the picture. Also both dowels are supposed to be the same size. You have two dowels of different sizes pictured. Good luck!
Posted February 13, 2016 - 07:42 AM
The one in the red circle does not belong there.  The arrow points to the return oil passage, which is supposed to have a dowel in it and an O-ring over the dowel, seated in the recess.
  • bikebuilder42
Posted February 13, 2016 - 11:51 AM
Its a 2004 yz450 and okay thanks, so what goes in that hole
  • bikebuilder42
Posted February 13, 2016 - 03:48 PM
Hey guys ended up removing the dowel and installing it to its correct place, everything lined up perfect thanks
Shout out to Grayracer513 & drtrcr400!!!!!! couldnt have done it without you guys
  • 5 replies
  • Hot  36 replies
  • Hot  33 replies
