2008 YZ450F.........to fix, or not to fix!
9 replies to this topic
  • Treeyz450
Posted February 12, 2016 - 08:50 AM
Ok, I have a 2008 YZ450F that I love, but, I had a catastrophic failure last week and lost a few valves. I just want your opinion on what you would do if it were your bike. I can do all the work myself as I am pretty mechanically inclined when it comes to these bikes. I'm just having a hard time spending 50% of what the bike is worth fixing it........
Here is the bike and the damage.......
It has brand new tires, suspension set for me, exhaust, and lower end which all has a few hours on it.ImageUploadedByThumper Talk1455295634.939451.jpg
Ok, so basically, the bike needs a new head, valve assembly, cams, etc.
it also needs a new cylinder and piston.
Which will all cost between $1600-1800.
So, my question to you is this.................fix an old bike, or wait and go get a newer one........money is somewhat of an issue.
Thanks in advance!!!!!
I also might add that it's pretty important that I have a bike because my 10yr old son is starting to race the MX and off road series here in MO.
Edited by Treeyz450, February 12, 2016 - 08:54 AM.
Posted February 12, 2016 - 09:28 AM
On the plus side, there are two or three very reputable outfits that can fix cylinder heads that look like they sat on an IED for less than half the price of a new blank head, so that would reduce it by about $3-400,  On the negative, if the piston slammed valve chunks into the head, you should either have the crank very carefully inspected, or just replace it outright, so it's kind of a wash.
An alternative is to go find another YZ450 in running condition and use your old stuff on it or sell your original as is to defray the cost.
  • Treeyz450
Posted February 12, 2016 - 10:10 AM
I hear that. I have a buddy who just broke his femur at the track, and has the same year bike with 4 sets of plastic, dr d exhaust, rekluse, and lots of other goodies, I would love to have , I just don't have the extra $$$$ laying around right now.
Are the 06-09's pretty much the same bikes minus a few small details?
I know the cams and CDI Are different, just so I know what to look for?
  • Treeyz450
Posted February 12, 2016 - 10:12 AM
Also, I got a rough estimate from edco, and they were at $850 without valve assembly.
I can get the GTYR ported head for $1295 which is a complete head with valves and cams ready to bolt on.
I am trying to sell my 02 CBR 954 RR to recoup some cash..........
Edited by Treeyz450, February 12, 2016 - 10:13 AM.
Posted February 12, 2016 - 10:56 AM
The '06 through '09 are mostly identical and interchangeable except for three things:
The front brake (everything but the rotor) from '08 onward uses a different master cylinder, brake lever, and caliper, and to accommodate this, the mounts on the fork lugs are different.
The "fat end" of the '08 and onward front axle is smaller, so the fork is different.  All four models use the same front wheel, though, just the axle is different.
The '09 uses a 25 mm rear axle, while earlier bikes use a 22 mm.  No easy conversion exists but the swing arm and linkage can be swapped to work around this.
Did the $850 include all the parts, or just the head with guides and seats?
  • Treeyz450
Posted February 12, 2016 - 11:44 AM
Posted February 12, 2016 - 12:27 PM
So the $850 included the cylinder and piston.  You'd need that with the GYT-R head anyway, so it's really more like $600 for the head, plus valves.  The GYT-R does start to look better.
  • Treeyz450
Posted February 12, 2016 - 02:49 PM
Actually, for 5 new seats, 5 new guides, 5 new seals. And, the $552 was only to fix one of each.
$748.25 + whatever labor to fix the other 4 assuming they all need it.
Plus this looks to be the way to go.......ImageUploadedByThumper Talk1455317387.852988.jpg
  • Monkeybutt2000
Posted February 13, 2016 - 02:43 PM
So what does your buddy want for his bike?
  • Treeyz450
Posted February 14, 2016 - 10:59 AM
$3000
  • 10 replies
  • 5 replies
  • Hot  28 replies
  • Hot  30 replies
