426 case won't fully separate
5 replies to this topic
  • cobra0702
Posted February 10, 2016 - 06:14 AM
I have the case fully separated in the front but the rear is only apart about 3/8 of an inch. I can still see that the guides are in both sides of the case on the rear. I'll post some pictures later on today, I could be forgetting to remove something but I'm just not 100% sure and don't want to force or pry on anything.
Posted February 10, 2016 - 10:38 AM
The crank will sometimes need to be pushed out of the main bearings using a puller.  See the manual.
  • cobra0702
Posted February 10, 2016 - 11:14 AM
What is the best way to remove the primary drive gear nut, I have tried putting a penny in the gears with the clutch basket on but it only crushes the penny and I get no movement on the nut
  • cobra0702
Posted February 10, 2016 - 11:23 AM
Am I forgetting something?
Posted February 10, 2016 - 02:07 PM
An air impact will take the nut off, and it's your best option now that you have it that far apart.
You should have removed the shift shaft prior to disassembly.  Also, the snap ring and idler gear should be removed from the output shaft right end.  Otherwise, it looks like you have the rear of the cases in a bind.  Run a pry bar between the two lugs in the red circle following the dotted line and pry there (prudently).  It's what they are there for.
  • billygildark5007
Posted February 10, 2016 - 07:28 PM
Next time this works a little better than a Penny but will cost you 1100% more. Lol.
Or try putting penny in a vise and bending it at a 90 angle.
  • Hot  50 replies
  • 10 replies
