2010 Yz450f cylinder/piston scarring after blown headgasket
3 replies to this topic
  • MiranAdam16
Posted January 31, 2016 - 04:14 PM
Recently my 10 450f started pissing coolant out of the overflow under heavy acceleration. We decided it must be a blown headgasket.
After tearing it down we noticed some pretty bad scarring on the piston and a little in the cylinder too.
What do you guys think could have caused this? I had just put a high flow water pump and new mishimoto radiators to resolve an overheating issue.
I guess it's big bored time, any kits you guys recommend? Any supporting mods recommended?
Thanks in advance for any info, Adam
Edited by MiranAdam16, January 31, 2016 - 04:16 PM.
Posted January 31, 2016 - 04:49 PM
That looks like classic piston seizure, in this case most likely as a result of the overheating condition causing a clearance problem or an oil failure.
If you're going big bore, have the crank balanced for the new piston.  Use a two compression ring piston for best longevity.
  • MiranAdam16
Posted January 31, 2016 - 05:07 PM
Do you think the cylinder is worth using again with a stock replacement piston?
Edited by MiranAdam16, January 31, 2016 - 05:13 PM.
Posted February 01, 2016 - 07:22 AM
Doesn't look like it.  But, if you can hone it clear of any scoring/marks and then measure it to be worn less than .002" anywhere, it could be.
  • Hot  113 replies
  • Hot  47 replies
  • 0 replies
Motocross
  • Hot  491 replies
  • 9 replies
