Fork oil question?
2 replies to this topic
  • XrFreakXr
Posted March 04, 2004 - 11:47 AM
How do I add more fork oil to my 93 xr600r?
  • AzMtnThumper
Posted March 04, 2004 - 07:39 PM
With your bike on a stand and the handlebars loose:
1. Loosen your upper triple clamp bolts.
2. Loosen your fork caps and inspect your O rings.
3. You will need to hold your fork cap with a wrench and
loosen the "lock nut" on the end of the rod. The rod
will fall down into the fork tube-that's OK.
4. You will need to place something under the front wheel
to completely collapse the front forks (wood blocks, or
maybe a floor jack).
5. Pull out the fork springs and any preload spacers and
washers that may be on top of them.
6. With the forks completely collapsed measure from the top
of the fork tube - the oil level should be between 135mm
(5.31 in) -115mm (4.53in) from the top of the fork tube.
I'm using 5wt fluid (Honda SS-7) at 120mm.
7. Put everything back together in reverse order with the
following torques:
lock nut under fork cap: 60nm (43ft lbs)
fork cap: 23 NM (17 ft lbs) coat the Orings w/ some oil
upper pinch bolts 28 NM (20 ft lbs)
handlebar pinch bolts: 27NM (20 ft lbs)
Have fun it's not as bad as it sounds. :)
  • XrFreakXr
Posted March 05, 2004 - 04:44 AM
thanks for the useful information. :)
  • 17 replies
Honda XR650L 2016
  • 0 reviews
  • 9 replies
  • Hot  60 replies
