02 WR426 Ticking when moved around in neutral w engine off
Yamaha WR450F Yamaha WR426F Yamaha YZ426F Yamaha WR400F
1 reply to this topic
  • Alwaats
Posted January 25, 2016 - 10:33 PM
Hey Guys, i've noticed a ticking noise when i'm moving my bike around. It's quite loud and i thought it was just the chain on front sprocket but on closer inspection the sound does not match the rotation of sprocket tooth/chain so it really must be coming from the sprocket shaft inside the gearbox. Having never had this box apart and facing a mammoth task if i do so, would anyone have some advice or history with this? is it normal? wear and tear and to be ignored? or is it undercutting/mis-alignment of gears and about to grenade on me?
Posted February 02, 2016 - 01:41 PM
IF the ticking happens in neutral while pushing the bike, and more closely matches the frequency at which the output shaft makes a full revolution than anything else, it is likely that there is a problem with the 4th or 5th gear pairs, as those two are splined to the output shaft, and are the only things turning in the gear box under those conditions.  The problem might be a broken tooth, or it might be a bent shift fork allowing one of the two gears to strike its neighbor as it turns.
If you remove the clutch, you can then turn the main shaft by hand and try the noise in neutral and in both 4th and 5th to see if you can further isolate it before the tear down.
Valve Cover gasket keeps blowing by pbcrazy9898
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  29 replies
Should i switch to a ktm 300 exc or xcw from a 2009 wr 450f by Tattoojunk
  • Hot  76 replies
2015 wr450 engine knock. Video inside. by cdf450
  • Hot  60 replies
Wr450f at higher speeds wobbles quite a bit by Turtlerider
  • Hot  28 replies
  • 0 replies
