2015 Yamaha YZ40F Turning issue.
8 replies to this topic
  • stevendickey
Posted January 23, 2016 - 11:56 AM
i cannot sit up on the gas tank taking a root around the corner. the front tire drives like a knive. what is the stock offset for the triple clamp? and any suggestions on what aftermarket triple clamp to buy?
  • stevendickey
Posted January 23, 2016 - 11:59 AM
its a 2015 yamaha yz450f
  • Monk
Posted January 23, 2016 - 12:09 PM
What's you weight, spring rates, sag, tire pressure, fork height?
Any suspension work done?
Is this entering the corner? Mid? Exit?
On the throttle? Off?
  • GHILL28
Posted January 23, 2016 - 01:30 PM
I highly doubt you need a different triple clamp offset.  There is a LOT to be accomplished with fork height, sag, springrates, and rear axle position before even considering triples.
  • stevendickey
Posted January 23, 2016 - 02:20 PM
when i enter sharp inside root and mid. the front end bites wile in a normal corner position of sitting up on the tank. i have to slide into the middle of the seat in order for it to track around the root
6'5 200lbs.
would a lower link for the rear end help?
  • stevendickey
Posted January 23, 2016 - 02:21 PM
off throttle and bites like a knife as i go to hit the throttle
  • GHILL28
Posted January 23, 2016 - 02:23 PM
Just run more sag to start with. 110-112mm isn't unreasonable. I found both ends to be a little busy with 100mm sag.
  • stevendickey
Posted January 23, 2016 - 02:36 PM
what about 105mm i been hearing that alot on youtube vids? so your saying 100mm might be good to go with?
Posted January 24, 2016 - 08:55 AM
Are you saying "route", "root", or "rut"?
No, he's saying that's not enough.  try something in the 108-114 range to make the head angle less steep.
How much do you weigh?
  • Hot  47 replies
  • 5 replies
  • Hot  36 replies
  • Hot  28 replies
