Baja Designs WR 400/426/450 General Discussion
16 replies to this topic
  • Baja Designs
Posted January 22, 2016 - 09:02 AM
Hello WR 400/426/450 Owners,
Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the WR400/426/450.  We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Accessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments WR 400/426/450 related!
Thanks!
  • Dualsportwr450
Posted January 22, 2016 - 09:25 AM
ImageUploadedByThumper Talk1453483405.106960.jpg ImageUploadedByThumper Talk1453483443.025149.jpg ImageUploadedByThumper Talk1453483473.245799.jpg
Best off-road light I've ever used. HUGE FAN!!
  • Super_Davee
Posted January 22, 2016 - 09:39 AM
Does your LED replacement headlight  for the 2015 WR450 require any modifications to the charging system?
  • Dualsportwr450
Posted January 22, 2016 - 09:55 AM
I had a 2012 and it did not
  • Baja Designs
Posted January 22, 2016 - 09:57 AM
For the 2015 WR450F you will have no problems running the XL Pro Kit.  No modifications required
XL Pro WR250F (2015) and WR450F (2012-2015) Kit
http://www.bajadesig...Wr450f-20122015
MSRP: $374.95
ThumperTalk: $337.45
Edited by Baja Designs, January 22, 2016 - 09:58 AM.
  • Gabex35
Posted January 22, 2016 - 10:53 AM
Will this light work with the High/Low switch from your dual sport kit?
  • Baja Designs
Posted January 22, 2016 - 12:49 PM
To get this light to work as a Low Beam and High Beam you will need our DSK Skene Dimmer Kit.    That will allow your desired brightness on low beam and full power on high beam.
When ordering, specify that it is for an XLPro.
http://www.bajadesig...kene-Dimmer-Kit
  • BolinJrsPit Crew
Posted January 22, 2016 - 06:47 PM
Have you guys had a chance to mess with the FX at all. I would like to install a light.
  • Dualsportwr450
Posted January 22, 2016 - 07:14 PM
To Baja designs. You guys need to build in an adjustment screw into the xl pro for the new wr 450s. It aims to high especially when your riding the back end squats and puts the beam way too high
Edited by Dualsportwr450, January 22, 2016 - 07:14 PM.
  • RockerYZWR
I have the same question.
  • patrick2wd
Posted January 23, 2016 - 02:33 AM
how about this:
made in Italy..
here mounted on a Gonda..
Edited by patrick2wd, January 23, 2016 - 02:37 AM.
  • Kx250FRiDeR651
Posted January 23, 2016 - 08:25 PM
I have the dual sport kit on my 15' wr450 and the XL pro, so this is plug and play and will let the high button on the handlebar light switch DS Kit work correctly?
I don't really care about the brightness settings just want the high/low to work.
Ya no matter how I angle the light and tighten the bolts down on the side, it only stays aimed for a min and vibrates its way back up blinding everyone if I'm on the street.
  • Baja Designs
Posted January 26, 2016 - 09:28 AM
Thank You for your feedback. I will forward it over to our product development team and we will look into possibly making some changes.
  • Baja Designs
Posted January 26, 2016 - 09:29 AM
Correct. This will allow your DSK High/Low beam switch to work and control the brightness of the light.
  • Kx250FRiDeR651
Posted February 09, 2016 - 04:39 PM
Is there any good write ups or instructions how to put this in for the new wr450? like how the dual sport kit instructions are super user friendly. the instructions apear to explain how to custom wire it in. This kit is all plug and play, but the black pigtail I cannot find anyplace where it would be plugged in at Im searching all over. And the white pigtail is already used to plug the xl pro in as the dual sport kit eliminates the factory headlight plug?? The only thing left is the red wire for power wich isn't an issue.
  • 13+
Posted February 22, 2016 - 12:35 PM
I have floated the ground on my 07 wr450f. Iv searched for answers and found none that helped me. I looked in my manual and no help.
I have the TT R/R it has 2 yellow wires and black, red. The bikes R/R plug had yellow, white, red and black.
Do i hook it up; yellow yellow, yellow white, black black and red red. Or do i hook it up; yellow yellow, yellow white, then run the black and red stright to battery?
Also do i have to do anything to the cdi wiring. From my understanding cdi is 12vdc and nothing is needed.
Thanks for the help in advance.
  • Baja Designs
Posted February 24, 2016 - 08:48 AM
The best bet for you would be to call Trail Tech (TT) if you're going to be using their parts for a kit.
We don't have all of the information on how the kits are wired.  Sorry about that!
Thank You,
Bailey, Baja Designs
