  • Instagram
Related Garage
Yamaha YZ450F (2016)
Owner: 1973 Honda XR75
Added on January 10, 2017
Related Reviews
Baja Designs 900mah Wired Ni CD Battery
Last review by rc64597
Yamaha YZ450F 2010
Last review by Dmeiborg
Baja Designs Billet Passenger Foot Pegs
Yamaha YZ450F 2016
Last review by YZJeffro64
Baja Designs Squadron LED Motorcycle Lights
Last review by JustTakeItEasy
Baja Designs YZ 400/426/450 General Discussion
Brand Baja Designs Yamaha YZ400 Yamaha YZ426F Yamaha YZ450F
54 replies to this topic
  • Baja Designs
Posted January 21, 2016 - 06:30 PM
Hello YZ 400/426/450 Owners,
Bailey here with Baja Designs.  We recognize ThumperTalk as one of the go-to sources for information on the Yamaha YZ 400/426/450.
We would like this thread to be a General Discussion area for members and guests to discuss Dual Sport Kits (DSK), Lights, and Lighting Acessories based upon stock and modified charging systems.  Please Post up if you have any questions or comments YZ 400/426/450 related!
Thanks!
  • Nik_Yz400
Posted February 03, 2016 - 12:21 PM
Thanks!
Do you offer a replacement stator for a 99 Yz400? I need one to keep battery charged/topped off
  • Monk
Posted February 03, 2016 - 12:55 PM
All my questions were answered regarding the Dual XL Squadron light setup. My stock 2015 YZ450F stator can only power on light at 40w, the other will have to be a battery system.
I guess, a good question to ask is which one should be on the battery system and which on should be off the bike?
Explain again why a OnX lightbar with a battery combined with a single XL pro (in a WR headlight mask) wouldn't be equally as good? In terms of simplicity I can leave the XL Pro on all the time and attach the OnX lightbar on when needed...
  • Monk
Posted February 03, 2016 - 01:08 PM
This
vs this...
  • Baja Designs
Posted February 11, 2016 - 09:51 AM
We do not offer a replacement stator for the 99 yz400.  For 98-02 we recommend purchasing WR400/426 stator, flywheel, and CDI.   This will boost your output to 130W
  • Baja Designs
Posted February 11, 2016 - 10:02 AM
Your bike can run up to one of our XL Pro Lights.  The problem with going with the dual XL Pro option is the factory charging system will not be able to keep up with 80W total draw.  If you add a battery system You will end up draining the battery in a matter of minutes.  We can setup a Dual XL Sport Setup that will draw a total of 40 Watts.  It is something that can be done fairly easily.  It would be a custom setup that we can build here.
Comparing an XL/OnX setup and XL/XL setup the Dual XL's will provide more output in near field, mid field, and distance.  The larger reflectors in our XL Series lights provide more distance and overall light output.
Both setups would be a huge improvement over the factory lighting setup.  Let me know if you have any questions!
  • Monk
Posted February 11, 2016 - 10:26 AM
No, we got it all figured out over the phone with Devin... Can't wait for the lights to arrive! $1250cnd pesos made for many extra nights flipping fries...
  • GHILL28
Posted February 11, 2016 - 01:03 PM
I have a Squadron Pro http://www.bajadesig...Number=497001WT and I'm wondering if there is a way to mount the thing in a stiffer fashion to the fork tubes?  Going over rough terrain the light bounces a lot.  Aside from that, works killer!
  • Baja Designs
Posted February 11, 2016 - 03:04 PM
We do have a tecate mount that uses rubber lined metal clamps instead of the full rubber clamp.  It can be found here for $19.95
http://www.bajadesig...ndard-Mount-Kit
This setup greatly reduces any vibration in harsh riding conditions. It will work great with your Squadron Pro setup
Edited by Baja Designs, February 11, 2016 - 03:06 PM.
  • GHILL28
Posted February 11, 2016 - 03:06 PM
Bingo, thanks!
  • Summit
Posted February 20, 2016 - 05:49 PM
What kit would you recommend for a 2016 450fx for just a basic headlight and a tail light/brake light?
  • Monk
Posted February 20, 2016 - 05:58 PM
GHILL28 has the Squadron setup and likes it...
http://www.bajadesig...Number=497001BU
I don't think he runs a tail light though. I run a Polisport unit as its fairly trimmed...
Edited by Monk, February 20, 2016 - 06:10 PM.
  • Baja Designs
Posted February 24, 2016 - 08:40 AM
What type of riding are you doing?  We do have a few options that will work for you based on your intended use for the kit.
Thanks!
  • Summit
Posted February 25, 2016 - 05:20 PM
Thanks!
I really just want something close to a stock wr setup, not looking for anything brghter. Don't even use lights just want something that looks legal.
  • S.back
Posted February 28, 2016 - 02:40 PM
Question. Finally got a night ride in with squadron pro and the problem I'm having is at low rpm the light flickers. Is this normal? Makes it hard to ride single track with the light flickering. My other question is the directions say to plug harness in on right side next to radiator. On the 16 there is no wire. Is the connector the one going to capacitor?
  • Captn Kirk
Posted March 02, 2016 - 06:05 PM
Thanks!
As of tonight, a friend just brought me his 2008 YZ450R and it is a dead spark situation.  Told him that if we end up having to replace the stator, might as well set him up with one of your so he can carry the load of a light on it.  Do you make a stator for this bike?  If so, can you tell me how to validate the OEM stator is faulty before I spend his money?
...................................just pulled the unit apart and my visual inspection uncovers a burnt wire, so I believe the question becomes, what do you have for this model and what upgrade would you suggest if any are available i.e. using near relative components like from the WR, etc?  See attached picture
Edited by Captn Kirk, March 02, 2016 - 08:36 PM.
  • D_Bergstrom
Posted March 06, 2016 - 04:38 PM
Any info on adding a light to the new YZ450FX? Guessing at the minimum it can handle 40 watts like the YZ450R, but hoping that since it has electric start, might be a little more power avaialble.
Doug
  • Monk
Posted March 06, 2016 - 06:12 PM
Doug
100w available on FX and WR...
  • Baja Designs
Posted March 09, 2016 - 03:03 PM
Unfortunately we do not have anything for the 2008 YZ450R.  1998-02 and 2010-On at the bikes that we have information for.  Nothing in between for these bikes
  • Baja Designs
Posted March 09, 2016 - 03:08 PM
Doug
It can definitely run our Squadron Pro!  We are actually working on producing a few Dual Sport Kits for the YZ450FX.  See below:
2010-15 w/ Halogen Light
http://www.bajadesig...Efi-Yz450f-1015
2016 w/ Halogen Light
 http://www.bajadesig...250fxyz450fx-16
2016 w/ XL Pro (Pre-Order)
If you are looking to run a simple On/OFF LED Light and Tail, we have this harness:
http://www.bajadesig...and-Yz450f-14on
+ EFI Taillight:
http://www.bajadesig...-Dual-Sport-Kit
+ The desired LED Light of your choice.  (Squadron Sport, Squadron Pro, S2 Pro)
  • 5 replies
  • Hot  28 replies
  • 0 replies
  • Hot  47 replies
