01 426 kickstart ceased
14 replies to this topic
  • cobra0702
Posted January 21, 2016 - 07:08 AM
Hello everyone, new to TT.
Just bought an 01 YZ426F and the kickstart is ceased up. I have not been able to take anything apart yet to inspect but I plan to do so when I get home. I'm just looking to see if anyone can provide me with some insight and if this is a common issue. Hopefully it's nothing too major and can get it running soon.
  • alex_naumov1
Posted January 21, 2016 - 07:20 AM
Seized? Or the crazy compression? Did you try kicking it with the decompression lever?
Posted January 21, 2016 - 07:59 AM
This can be anything from a seized crank to a jammed up starter gear.  Exploratory surgery is required.
  • cobra0702
Posted January 21, 2016 - 08:01 AM
I did try pulling the decompression level and it felt like it was working. Could I also try removing the spark plug?
That's what I figured I was going to need to do
Posted January 21, 2016 - 08:09 AM
OK, wait.
You can turn it over with the compression release pulled?  Then nothing mechanical is frozen up.  You cannot expect to be able to kick a healthy YZ426 through its compression stroke without assistance, thus the decomp lever.  The correct procedure is to push (not kick) the starter down until the engine stops against compression.  Hold the starter there, pull the compression release and push the starter down about 1 to 1 1/2" farther and stop.  Release the compression lever, return the starter to the top and kick through the full stroke forcefully but smoothly.
Watch: http://api.viglink.c...troke_vid_a.mpg
http://api.viglink.c...troke_vid_b.mpg
  • cobra0702
Posted January 21, 2016 - 08:14 AM
OK, wait.
No it did not fully kick it's still seized with the level pulled but I was saying that it felt like the level is working
Edited by cobra0702, January 21, 2016 - 10:38 AM.
  • cobra0702
Posted January 21, 2016 - 08:16 AM
Previous owner just told me he fired it up one day and when it was warming up it started sputtering and shut off, then would not budge when kicked
Edited by cobra0702, January 21, 2016 - 08:17 AM.
Posted January 21, 2016 - 09:26 AM
"Seized".
Probably the rod big end bearing.
  • cobra0702
Posted January 21, 2016 - 10:35 AM
"Seized".
How expensive/ difficult is it to fix that
  • cobra0702
Posted January 21, 2016 - 10:49 AM
Okay I just figured out that the bike will not move in gear with the clutch pulled in. It will only roll in neutral. Does this mean the issue is located in the transmission?
Posted January 21, 2016 - 02:05 PM
It's pretty typical for the bike to hard to move in gear when not running, so I doubt it.  The crank is a $400 item, and if it need or the trans replacement, the entire engine must be disassembled.
  • cobra0702
Posted January 21, 2016 - 07:18 PM
So I took the top end off and the cam chain is extremely tight, does anyone know how tight it is supposed to be? There is absolutely no play whatsoever. I am currently stuck with one of the stator plate torx bolts because it was rounded. Does anyone know what material the plate is made of that holds the stator? I might have to weld the torx socket to the bolt to get it out and I am unsure about heat transfer.
Posted January 21, 2016 - 09:27 PM
Well, that's one approach.  The stator plate is aluminum.  If you're going to use an electric welder, shield the coils from the arc and be sure the stator harness is disconnected.  The plate itself should be alright as long as you don't arc to it.
There are other ways..
The chain will always seem very tight when it's cold as long as the tensioner is working right.
  • alex_naumov1
Posted January 22, 2016 - 06:55 AM
So, how much did you pick this 426 up for?
  • cobra0702
Posted January 22, 2016 - 08:29 AM
Paid 700 and other than not kicking it's in really good shape
Edited by cobra0702, January 22, 2016 - 08:31 AM.
  • Hot  38 replies
  • 5 replies
  • Hot  28 replies
  • Hot  47 replies
