Fork Tube Height
8 replies to this topic
  • Rokatt88
Posted March 03, 2004 - 02:57 PM
OK, all you So Cal & Baja Desert Dudes. How many millimeters are you running on the fork tubes? 5mm? I had taken off my forks and had some suspension work done. It took them a while to do it (a month). I know...I should have marked or measured it before I yanked them off. Anyway I forgot the exact setting. I put them back right up to the fork cap at first and believe me, if you want it to turn...Don't Do That! I popped them up out in the field, approx 5 mm. Is there a good all around or prefered measurement? Sorry for the Spode-like question but I do respect the opinions of my peers! :)
  • qadsan
Posted March 03, 2004 - 03:26 PM
I'm not sure what others are using for their measurements, but mine are set at 2.45mm based on my digital vernier :)
  • Dave102429
Posted March 03, 2004 - 03:29 PM
When I had my suspension done, I was told to set the forks at 5 mm for desert and 8 mm for a grand prix track. This was messured from the top of the upper tripple clamp to the top of the edge of the fork cap. I've been thinking about trying 10 mm for some tight trail riding.
  • JackAttack
Posted March 03, 2004 - 03:33 PM
7mm without the caps. I'm using an Applied top triple clamp. :)
  • Rokatt88
Posted March 04, 2004 - 05:50 AM
Ahh yes....I forgot to mention that I am using a BRP top clamp. I believe they are very close to the Applied design. Think I'll try 7mm this weekend.
...."Gladiators...I salute you!" :D
  • pchansen
Posted March 04, 2004 - 10:02 AM
I run 8mm W/3wt Maxima oil set at 120mm with .47 Racetech springs. Mostly trail riding. Still tinkering with compression and rebound settings but overall this seems to be a good starting place.
Paul
  • Rokatt88
Posted March 04, 2004 - 10:29 AM
Yep, Got my scoot all Race Teched out. .47 springs in front with 10 Eibach on the rear. Race Tech Ultra Slick @ 130mm with gold valves. Be Mo-Tat-In' one time! :)
  • Rokatt88
Posted March 08, 2004 - 11:32 AM
Jacky Attacky!
Ran 7mm last Saturday. Bike carved turns like a jigsaw.
:D :) :D
  • JackAttack
Posted March 08, 2004 - 11:50 AM
:) :D :D
Honda XR650L 2017
  • 0 reviews
  • 3 replies
  • 8 replies
  • Hot  60 replies
  • Hot  171 replies
