trouble starting 2005 YZ450f
5 replies to this topic
  • dattorob
Posted January 20, 2016 - 11:23 PM
Hi there
A while back i began having trouble starting my 450. I suspected it was the valves as the hours
were getting up since rebuild.
So i reshimmed them , only one intake valve was slightly out of spec.
I also cleaned the carb whilst i had it apart.
I put it all back together and seems even harder to start.
The only way i can start it now is by push starting it, and then if it fires keeping
the throttle on etc, even then it dies quickly, but at least it does start.
I did put new fuel in and made sure the airfilter wasn't over oiled.
I suspect the carburetor still isn't right?
Would that plate that goes onto the slide inside the carburetor possibly
cause these sort of issues if i mistakenly got it upside down?
Also i noticed the bowl leaking a bit which it didn't used to so maybe that
needs adjusting.
Appreciate any ideas.
regards
Robert  :banghead:
Posted January 21, 2016 - 07:57 AM
Yes, the slide can be, and commonly is, installed upside down by mistake.  "Square" end goes down, not the rounded one.
If the float bowl is leaking from the gasket, it's just a leak.  If it's leaking from the center drain/overflow tube, it's flooding.
  • dattorob
Posted January 21, 2016 - 09:14 AM
OK thank you ☺
  • dattorob
Posted April 19, 2016 - 11:55 PM
just thought i would report back to say, i got the carb rebuilt by tokyo mods and then still had a bit of trouble starting so i dropped the pilot jet down a few sizes to a 42, whammo all sorted, easy starting. cheers  :thumbsup:
  • w0200320
Posted April 20, 2016 - 04:45 AM
I have been sorting the same issue with my 08. I figured stock pilot should work at msl and arid 15 degree Celsius but it was just too rich. 42 pilot for the win!!
  • dattorob
Posted April 20, 2016 - 05:56 AM
ok thats great. I might add that i have a fair few mods done to my engine. Also altitude here is around 1000ft. I guess there are lot of variables that influence jetting.
  • Hot  47 replies
  • 5 replies
  • Hot  113 replies
