2016 WR450 Ride Report & Opinions
Yamaha WR450F 2012
226 replies to this topic
  • KennyMc
Posted February 12, 2016 - 07:38 AM
The last two oil changes I overfilled it. It says it takes about 3/4 of a quart on an oil change? The first time I put a quart in it this time I put less than a quart in it. I am way over the sight glass. However it hasn't puked out yet even with all those hill climbs. I haven't seen any bad results. I feel guilty just adding over half a quart on a oil change.
Maybe I need to get use to it or use the oil level screw next to the sight glass. The 07-11 always took a quart any more and they would puke out oil from the breather tube.
Dang, you sure you're draining all the oil out? Sure there's not a 2nd oil plug? My KTM has 2. It's just, dayum, just over a half quart of oil? :shocked:
  • stevethe
Posted February 12, 2016 - 08:47 AM
According to the book it doesn't take much. The drain plug looks like it's on the very bottom of the motor.
  • RMK800
Posted February 12, 2016 - 09:41 AM
The manual only specifies one drain plug. I'm with Steve, 3/4 quart just doesn't feel like enough. That's even with a filter change.
  • Monk
Posted February 12, 2016 - 10:51 AM
Without a filter change its only 650ml. The bike's don't hold a lot of oil...
  • KennyMc
Posted February 12, 2016 - 11:17 AM
Does the manual say it holds .95L? That would be a quart wouldn't it?
  • Monk
Posted February 12, 2016 - 11:36 AM
Completely empty...
  • Chaconne
Posted February 12, 2016 - 01:52 PM
Well my 2014 has more than one. It has 2 engine plugs mid and back and the lower oil filter bolt acts as drain as well. Guess they changed things in 2016.
  • Super_Davee
Posted February 12, 2016 - 04:27 PM
I did notice when draining the oil that tilting the bike over to the throttle side allowed a lot more oil to drain. I always shim the kickstand to keep the bike upright during the whole process, but wanted to share that.
  • Motodisiac
Posted February 12, 2016 - 10:25 PM
So tonight I installed GYTR exhaust tip with larger opening. I was thinking about getting FMF pipe instead, but two lbs savings were not enough to offset a bike that is too loud. Instead, I ordered larger exhaust tip, overpriced for what it is, $50.
Yamaha says its 96db. I was hoping it's less and I wasn't disappointed. It flows a lot more than stock uncorked tip, yet it's not a lot louder, just enough to be nice without being obnoxious. I actually measured db rating with an app and it was no more than 87 while revviing the engine.
I finally got a chance to install some maps into GYTR tuner, so I will get a chance to try them on Sunday. Any good maps for stock uncorked bike?
  • stevethe
Posted February 13, 2016 - 08:23 PM
The all zero map is supposed to work with just a pipe. I also posted a fx map that seems to work.
  • KennyMc
Posted February 14, 2016 - 10:41 AM
Not much ride reporting going on. You still just ogling over it :D All the "animals" hibernating? ;)
  • RockerYZWR
Posted February 14, 2016 - 12:24 PM
Dance, monkey!
  • stevethe
Posted February 14, 2016 - 12:45 PM
No were riding. Went with my boy called the Boy Friday to the snake pit. Just keep dialing things in.
The Wolf has been out for a couple of weeks getting the KTM rebuilt.
  • KennyMc
Posted February 14, 2016 - 01:33 PM
Yea, I thought Wolfies bike was to be done at least a week ago :mechaniconvacation: ;)
  • 2Speed
Posted February 15, 2016 - 07:03 PM
Installed the GYTR ECU tonight, and removed the tea kettle. Someone needs to find the guy on the assembly line that installed the airbox and turn his impact gun WAYYY down. The screws holding the filter screen on were torqued way too tight. I stripped two getting them off.
The tea kettle came right off, though. I used some flush-cut snips and the plastic rivets practically fell off. They came off so clean you can barely tell they were ever there.
  • Super_Davee
Posted February 16, 2016 - 06:00 AM
Installed a stock YZ slip on last night. Rode it to work this morning, and it feels much better. Its only slightly louder IMO. Big difference in weight between the two.
  • stevethe
Posted February 16, 2016 - 06:13 AM
And rode it to work. You Dog.
  • Super_Davee
Posted February 16, 2016 - 08:56 AM
Hahaha, well i am in TX, but the bike is plated.
  • Macsplace
Posted February 16, 2016 - 10:27 AM
Mine is also plated, wish the weather would warm up enough to get some ride time in.
  • Macsplace
Posted February 16, 2016 - 10:35 AM
Oil change question, has anyone changed their engine oil by the manual including removing the oil check bolt and draining off any excess and if so what was your sight glass level afterward?
2012 WR450 Starting woes by W85W58
Dirt Bike   Make / Model Specific   Yamaha   WR 400/426/450
  • Hot  502 replies
2012 wr450 exhaust? What fits by Fvmcboy99
  • 20 replies
2012 wr450 headlight by donkeyballz
  • Hot  27 replies
2012 wr450f Idle issue by WeekendWarriorz
Dirt Bike   Dirt Bike Technical Forums   Intake - Jetting / Fuel Injection
  • 0 replies
GYTR/FMF Pipe Installation 2012 WR450F by Andrew Puetz
  • 2 replies
