Leaky air box?
10 replies to this topic
  • DangerRanger245
Posted January 17, 2016 - 06:09 PM
2015 WR
Ok, I oil the everloving shit out of my airfilters. I open it up to see this dust in the airboot. As you can see, I even grease the seal. Don't see dust in the grease. I THINK the clamp between the airbox and air boot is loose, or the connection is leaking. The dust on the upstream side of that connection is dispersed differently than downstream (you can see it if you look, the Allen wrench is pointing at the mating surface)
OR, the dust is leaking through the air filter where the plastic cage know slips through the filter..but that looked clean.
The clamp is in the top right hand corner of the airbox...it's impossible to tighten. It looks like there is no access and the airbox is riveted together. Clamp FEELS tight.
Help? Maybe I can put a ring of grease over the gap?
I just had valves checked, they were perfect. ...This is one ride,since then, maybe 2 hours of riding. Should I be worried?
  • Krannie McKranface
Posted January 17, 2016 - 06:41 PM
I'll bet the boot is not on all the way at the back of the carb.,.....
  • DangerRanger245
Posted January 17, 2016 - 06:44 PM
It's FI. So, throttle body?
  • DangerRanger245
Posted January 17, 2016 - 06:46 PM
How would dust go upstream in the intake ?
Edited by DangerRanger245, January 17, 2016 - 06:46 PM.
Posted January 17, 2016 - 06:50 PM
I'm not sure what it is, but have you lifted up the subframe and inspected the rear boot?
  • DangerRanger245
Posted January 17, 2016 - 06:53 PM
Looked at airboot. Haven't lifted subframe. How difficult is it to do that?
  • DangerRanger245
Posted January 17, 2016 - 08:26 PM
Well does anyone know how to get to the screw to tighten the clamp?
  • GuyGraham
Posted January 17, 2016 - 11:38 PM
Its real fine so i say its being pulled through the filter. I had same issue using a hiflo air filter. No issues now with oem filter and silkolene air filter oil
What filter and oil you using?
Edited by GuyGraham, January 17, 2016 - 11:41 PM.
  • DangerRanger245
Posted January 18, 2016 - 06:52 AM
Twin air or UNI with Fab 1 oil.
The UNI seems like it's much more coarse.
Edited by DangerRanger245, January 18, 2016 - 06:53 AM.
  • GuyGraham
Posted January 18, 2016 - 09:11 AM
I've no experience with either Twinair or Uni, so can't comment on how good eitherof them are at filtering the dust out
As its a 2015 bike, what happened to the OEM filter?
Go back to an OEM filter as a baseline and recheck
  • DangerRanger245
Posted January 18, 2016 - 04:29 PM
Can't currently find OEM one. I usually buy a few filters to keep a clean one always on stand by. Comparing the twin air to UNI, the twin air is definitely a finer media.
I siliconed the outside of the airbox where the boot connects, and switched to the twin air. Will report back after the rainy weather stops. Hopefully this issue is resolved and this thread can be helpful to someone else
