De restricting 2016 WR450
63 replies to this topic
  • Krannie McKranface
Posted January 18, 2016 - 03:41 PM
#21
Steve has some tricks up his sleeve.
I was privy to some of the things to come.
Can you say 'laminar flow' ?
  • stevethe
Posted January 18, 2016 - 07:10 PM
#22
Ah yes picked up a GYTR Cosworth ported head and cams.
  • stevethe
Posted January 18, 2016 - 07:15 PM
#23
Installed a Western Power Sports featherweight lithium battery. IMG_2768_zpsc58nanki.jpg
Posted January 18, 2016 - 07:22 PM
#24
^ ooooh ^    :worthy:  :worthy:
Great.
Now I'm going to start shopping for a Ti pipe for the Beet-ah.
Your fault.
  • stevethe
Posted January 18, 2016 - 07:29 PM
#25
Great.
Your fault.
Your Beta is a bitchen machine. Why not.
Posted January 18, 2016 - 07:40 PM
#26
Can't find a trick Ti header for it!
Might have to get some Eye-talian type.
  • patrick2wd
Posted January 19, 2016 - 01:28 AM
#27
You'll have to shop in France (maybe) and get a Dakar pipe for it.. +longer/ = better performance.. (&much wider)
Posted January 19, 2016 - 05:31 AM
#28
No low pipes for me.
  • stevethe
Posted January 19, 2016 - 07:01 AM
#29
Yea down pipes are not the current swag. Maybe for a road race bike or maybe the Dakar bike. Remember even Penton got a motorcycle to last 6 days in the ISDE.
  • KennyMc
Posted January 19, 2016 - 07:35 AM
#30
Or a 1974 Honda XR75. DG :thumbsup:
  • stevethe
Posted January 19, 2016 - 07:48 AM
#31
My XR80 with a XR200 motor stuffed into it. Varoooom pop pop pop.photo1_zpsdb564359.jpg
  • patrick2wd
Posted January 19, 2016 - 08:56 AM
#32
Thanks, I found it at Rocky Mountain. This is the kit with ECU, throttle screw and programmer for $313.99
The ECU alone is $98
https://www.rockymou...etition-Kit-ECU
that comes standard in the EU, "not for road use intended" :moon:
Edited by patrick2wd, January 20, 2016 - 04:45 AM.
  • patrick2wd
Posted January 19, 2016 - 11:56 PM
#33
Hows that new intake behaving...?
Any good?
  • stevethe
Posted January 20, 2016 - 07:43 AM
#34
Any good?
If you mean the new competition ECU it sounds different. Better rap off idle. It doesn't sound lean any more. I will know more on Sunday. The instructions say to set the ECU with all zero's with the intake derestricted and a pipe. That's the stock settings it comes with without using the tuner.
  • patrick2wd
Posted January 20, 2016 - 08:10 AM
#35
I decided to upgrade a bit on the filter holder. The one pictured is a Twin air powerflow kit with no screen for a YZ450.
The stock air filter is a bit puny the GYTR one looks like a Uni and looks the largest. However the glue has known to be junk on the Uni's so we will see if it holds up. The Twin air and the PC racing both look good.
and with this contraption??
  • stevethe
Posted January 20, 2016 - 08:28 AM
#36
Ah never rode it with the stock set up. Also to note the YZ cage is the same as the WR minus the tea kettle baffle. In the instructions with the GYTR ECU it tells you to grind off the plastic rivets to remove it. I have a spare YZ one if anyone needs it.
  • Super_Davee
Posted January 21, 2016 - 12:21 PM
#37
Just put my deposit down today. The bike should be at the dealer early next week, and they are going to plate it for me.
I'd gladly purchase the YZ cage from ya!
  • stevethe
Posted January 21, 2016 - 01:33 PM
#38
Your welcome to the YZ one but I wonder if the shipping would kill the deal. They cost $20. at the dealer or you can grind the rivets and remove the tea kettle for free.
  • Super_Davee
Posted January 21, 2016 - 01:38 PM
#39
Ah ha. I didn't know they were so cheap! Since i'm in TX, that would kill the deal after shipping. I'm sure someone closer to your hometown could put it to good use eventually.
  • 2Speed
Posted January 21, 2016 - 03:54 PM
#40
Which dealer is plating it for you? Are they going to charge you the 6% sales tax instead of the 8.25%?
