shift shaft on a 04 yz 450f
7 replies to this topic
  • dirtlife1990
Posted January 08, 2016 - 06:37 PM
My splines on my shift shaft are worn out how do I replace the shaft and I hope I do not half to split case I can't afford that and I'll be taking it to a shop plz give me info on this thanks
  • SAKs YAMAHA
Posted January 08, 2016 - 07:34 PM
Pull the right side outer case and remove the clutch assembly. After that it should be self explanatory.
  • mikedabike
Posted January 08, 2016 - 10:02 PM
Pretty easy fix. Get a manual. Make sure you get the kick starter gear spring in correctly.
  • dirtlife1990
Posted January 08, 2016 - 10:08 PM
This is the shaft that the shifter sits on to change gears the splines are worn down on them and justt can't afford to split the case
  • dirtlife1990
Posted January 08, 2016 - 10:10 PM
So I don't half to split the case to change out the shift shaft that my shifter goes on ?
  • SAKs YAMAHA
Posted January 08, 2016 - 10:18 PM
I am pretty sure you only have to pull the outer case and the clutch assembly. Definitely get a manual, it tells you everything. Yamaha manuals are the best, better that most military manuals. Also Google and YouTube are great.
Posted January 09, 2016 - 08:09 AM
No.  Just remove the clutch assembly.
  • dirtlife1990
Posted January 09, 2016 - 02:04 PM
Thank god that makes me feel better ...it shouldn't be that much to replace it I think like 39 for the part plus labor
  • Hot  28 replies
  • Hot  30 replies
  • 0 replies
