timing or carb??
3 replies to this topic
  • Valkman
Posted March 02, 2004 - 08:15 PM
This weekend I did the free mods. "air cleaner snorkel, grey wire and GYT-R exhaust insert. I went out riding today and my bike now runs like CRAP!! When I let off the throttle the engine idle speed stays way up for a couple of seconds before finally coming to a low idle. Also, it seems to backfire quite often now. Is the timing off since the grey wire was cut?? OR, do I now have to re-jet the carb?? OR, could it be a combo of the both? Has anyone else had this issue with their bike after doing the "free mods" on the WR450?? I hope you all can give me some good advice. :D :D :)
  • Agent
Posted March 02, 2004 - 10:53 PM
Yeah, your bike is running lean now. My bike did the same thing after doing the mods. I am in the process of figuring out the jetting so I am not sure what the exact solution is but you can read more than you ever wanted to know about jetting in this thread: http://www.thumperta...5/o/all/fpart/1
A good place to start is by picking up the James Dean jet kit found on this site.
  • jchantzWR400F
Posted March 03, 2004 - 03:33 AM
Without a doubt jetting, not timing. Take a look at the "Jetting Q's" section.
  • WR450F_RDR
Posted March 03, 2004 - 05:00 AM
No need to adjust timing after the mods, just modify your jetting. You might want to take a look at some of the Thumper talk members signature line to see what setup they are running, but the idea is: 168-170 main jet, 45-48 pilot jet and about 1-1/2 to 1-3/4 turns on the pilot air jet screw.
