2015 WR Corrosion/oxidation
7 replies to this topic
  • DangerRanger245
Posted December 31, 2015 - 04:34 PM
My 2015 is 4 months old. Garaged. Hosed after every ride. I live in Acton, it's desert. I noticed this today
ImageUploadedByThumper Talk1451608436.782246.jpg ImageUploadedByThumper Talk1451608450.112753.jpg
It's just the crankcase and header. My 06 YZ didn't do this, same environment.
Normal?
Do I even need to worry?
Edited by DangerRanger245, December 31, 2015 - 04:35 PM.
  • stevethe
Posted December 31, 2015 - 05:04 PM
Looks like you got something on it. Just wash it like normal. Your definitely not at the beach.
  • jimmym
Posted January 01, 2016 - 10:37 AM
That's a steel header, meaning it will start to rust anytime water and oxygen are present. You can dry it off after each wash, and I also spray it with WD40 to displace the water.
But yes, this is normal.
  • stevethe
Posted January 01, 2016 - 11:21 AM
It wouldn't be steel it would be stainless steel.
  • Krannie McKranface
Posted January 01, 2016 - 06:32 PM
Got to run the motor and get it HOT after washing or you will get calcium deposits on all the aluminum  parts that are not anodized....
  • 270winchester
Posted January 01, 2016 - 08:19 PM
I use compressed air to blow the water out of all the nooks and crannies and run it... Lots of work, but it ensures everything is good and dry.,, you'd be surprised how much water is hidden in your brakes, wiring, suspension, etc, that running doesn't address.
  • 270winchester
Deleted- double post
Edited by 270winchester, January 01, 2016 - 08:22 PM.
  • DangerRanger245
Posted January 03, 2016 - 07:37 PM
I never thought it was mineral deposits. Why would it only show on the crankcase and not the cylinder? Different coating on the aluminum?
