Post your woods built YZ's
30 replies to this topic
  • Monk
Posted January 04, 2016 - 08:48 AM
#21
What should I do to make it "proper"? I rode this bike before messing with the suspension. I have ridden friends bikes set up for MX, Hare Scramble, Enduro, etc. I still like being able to touch the ground. If you have any suggestion for me to make it better, let me know.
Because you have the desire to touch the ground fulfilled, changing anything will most likely result in your not liking the bike. It's not that your setup is wrong more then it might not be getting optimal handling because of the lowering. If you can touch and your happy, there isn't really any other better solution.
Ultimately lowering the suspension internally would be the ideal ticket but that comes at a cost.
  • SAKs YAMAHA
Posted January 04, 2016 - 08:53 AM
#22
Understood.
Posted January 04, 2016 - 10:56 AM
#23
It's also true that lowering the rear without a matching lowering of the front alters the steering head angle by making it shallower, which on a '10 or later may not be too bad a thing for off-road use, but you wouldn't want to do that on an MX bike or on an '09 or earlier model.  Shallower head angles contribute to understeer ("pushing the front"), and that tendency is bad enough as it is.
The fork simply can't be lowered 2" safely without internal modification (to say nothing of moving the handlebars).
  • SAKs YAMAHA
Posted January 04, 2016 - 11:15 AM
#24
Before and after. No "stink-bug", but the front end isn't too high either.
  • Wiz636
Posted January 10, 2016 - 10:23 PM
#25
Just finished getting it all ready for the 2016 race season
  • GHILL28
Posted January 11, 2016 - 10:23 AM
#26
2014
  • TRAILGUYAL
Posted January 24, 2016 - 09:03 AM
#27
2011 yz450f woods setup
All the usual goodies.
  • JonL515
Posted March 14, 2016 - 02:47 PM
#28
2014 YZ 450f woods set up
Evo suspension
Baja Designs Squadron Light kit
Unabiker Radiator Guards
SXS Skid Plate
GYTR 4.4oz Flywheel Weight
Tubliss set up
Cycra Bark Busters
Oversize Front Rotor
Updated motor mounts
To do:  Kickstand
  • skobiak
Posted June 07, 2016 - 06:30 PM
#29
Gotta grab a pic, but I have a Yamaha yz400f. It came with acerbis hand guards, white brothers pipe, and a moose racing skid plate. So far I've added a promoto billet kickstand, flatland racing rad guards, moose racing seal savers, led headlight, and a bib mousse in the rear. I have a 12 tooth front sprocket I may install also. Soon to be getting a yz450 carb, and possibly a different pipe. (The pipe has all the discs removed and is obnoxiously loud. It sounds awsome but I don't want to be that guy)
  • Navaho6
Posted June 08, 2016 - 08:24 PM
#30
2009 450
18" rear
13:51 gearing
Factory Connection revalve
Boyesen Supercooler water pump
Coolant catch tank
WR450 header
Heavy flywheel
Rekluse Core EXP 3.0 (not shown)
Scotts steering damper
Motion Pro T3 slidelight clutch cable
FMF Power Core
Rad guards
Handguards
Skid plate
Kickstand
252 lbs wet
Edited by Navaho6, June 08, 2016 - 08:29 PM.
  • hondaman331
Posted August 29, 2016 - 05:19 AM
#31
Probends and a skid plate....the rest stock. Was gonna get a rekluse but it will creep in second gear at about .5 mph and then jump to life like sea biscuit. No need to modify the 16.1472476667185.jpg 1472476678361.jpg 1472476692457.jpg
And a oring renthal chain and jt steel sprockets, stock gearing. Sorry.
