Coasting... engine off
6 replies to this topic
  • FTD
Posted March 02, 2004 - 01:31 PM
There's a section of trail we ride, slight down hill, through the brush that I turn the engine off and coast.
I was told this is bad for the tranny.
Is it bad or not?
Hoss
  • RichBaker
Posted March 02, 2004 - 01:38 PM
Is it bad or not?
Hoss
When the engine is off there is no oil circulated thru engine OR trans....a good way to riun the tranny.
  • endurodog
Posted March 02, 2004 - 01:42 PM
I have done this for years, but the bike is in neutral, and never had a problem. I got to do it down a few very long hills in past also, like miles long. Now if your tranny is engaged I could see a problem. Now you do loose some control.
A few years ago one of the big name guys, Berlson or maybe Roesler, can't remember for sure got hurt doing it. I've heard it called "Coast Racing" before.
  • FTD
Posted March 02, 2004 - 01:54 PM
Is it bad or not?
Hoss
That is exactly what he said... so it is bad, I should leave the engine on...
Hoss
  • PBDBLUE
Posted March 02, 2004 - 02:08 PM
The transmission is splash lubricated (not pressure like the crank/cams). It will not harm the transmission to coast in neutral.
  • RichBaker
Posted March 02, 2004 - 03:26 PM
My manual shows a lube path thru the tranny shafts....I wouldn't coast with the engine OFF, running in neutral sure. :)
  • faggio40
Posted March 03, 2004 - 01:13 PM
It's correct for two stroke, but not for four stroke, or not all but the large majority.
But it's true too that coasting in neutral there aren't big stress in tranny, so no problem for riding few miles with engine off. Many years ago I often used coasting with street-bikes with some friends of mine, and I and my friends never had problems to our bikes.
Coasting is very amusing: no noise from engine, so you can enjoy insulting your friends when you overtake them :)
