Bottom end mods
27 replies to this topic
  • SAKs YAMAHA
Posted January 25, 2016 - 09:47 PM
#21
Yep, but I don't think you can find a new one for $1600. Even adding the $1200 in parts and machine work comes in less than new. But there is definitely too much neglect.
The reason was the top end wasn't getting much oil. When I started flushing the oil ports, this thick play dough like sludge started coming out. So I am positive this guy missed a few oil changes. I'll have to get a picture of the sludge noodles, haha.
  • SAKs YAMAHA
Posted February 07, 2016 - 02:30 PM
#22
Ok so I tried to install the wr gears in the yz. I ordered the whole gear set minus the shafts. I decided to go with the whole 1-5 trans swap because i didn't want any gaps in the ratios and it just didn't seem like it would fit together with miss matched gears. Anyway, I ran into several issues and abandoned this part of the build until the next time I pull the engine apart.
Here is the list of parts i ordered:
5TJ-17151-20-00                GEAR, 5TH PINION (25T)
2GC-17131-00-00              GEAR, 3RD PINION (16T)
5TJ-17141-20-00                GEAR, 4TH PINION (20T)
5TJ-17121-20-00                GEAR, 2ND PINION (15T)   this gear is the same on both bikes
5TJ-17211-20-00                GEAR, 1ST WHEEL (29T)
2GC-17251-00-00              GEAR, 5TH WHEEL (21T)
5TJ-17231-20-00                GEAR, 3RD WHEEL (21T)
5TJ-17241-20-00                GEAR, 4TH WHEEL (21T)
5TJ-17221-20-00                GEAR, 2ND WHEEL (26T)
1. when completely assembled, the two sets didn't match up very well. I determined this was due to the bigger first gear. This will require a wr main axle shaft because the 1st pinion gear in built into the shaft.
2. so i proceeded with the yz 1st gear and the left shift fork won't fit into the 3rd pinion gear detent.
I don't want to run a hokey set up in a freshly built bike. So next tear down I will buy new shafts and shift forks and report back with the build. sorry if i left anyone in expecting more.
  • WouldsAssassin
Posted February 16, 2016 - 01:26 PM
#23
Thanks for getting that far. I Appreciate the progress report.
I knew the output shaft was needed for the other side of 1st gear. My plans were to get the entire set of gears and shafts and I was curious about the shift forks still matching up with the different cog set. When do you think you'll break it open again?
Posted February 16, 2016 - 02:13 PM
#24
Read through this thread:
http://www.thumperta...on-a-10-yz450f/
The '10-'13 forks have differing part numbers, from the later WR, but this user did not install them.
  • SAKs YAMAHA
Posted February 16, 2016 - 06:29 PM
#25
Maybe the end of this year, if nothing happens before then.
  • SAKs YAMAHA
Posted February 16, 2016 - 06:30 PM
#26
Thanks gray, I wish I'd have come across this before. My initial search turned up nothing. Guess I was using the wrong search words, haha. Thanks though.
Posted February 17, 2016 - 07:00 AM
#27
"Common Threads: Look here 1st! ..."
  • SAKs YAMAHA
Posted February 17, 2016 - 11:10 AM
#28
Haha, and that's one of the first thread in the forum. I feel dumb. Thanks again.
  • On Yesterday, 06:20 PM
  • 0 replies
  • Hot  28 replies
