07 YZ450F Gearing options, 47 or 48 tooth?
5 replies to this topic
  • Racinkc1
Posted December 16, 2015 - 02:08 PM
So this bike comes with a 49 tooth rear sprocket... Wanting longer gears. Should I drop 1 or 2 teeth? I know honda's come with 51 tooth rears and you usually drop 2 teeth to a 49 tooth to notice a difference... Would you try the 48 tooth first? Probably not?
  • stevethe
Posted December 17, 2015 - 09:11 AM
One tooth doesn't make a big difference.
  • cpetz24
Posted December 17, 2015 - 11:43 AM
Is this for moto or something else?  If you want to be able to feel a noticeable difference you're going to need to go at least 2-3 to tell significantly.  1 tooth is only a 2.1% change so it's going to be hard to notice.  If you go 3 now you're up to a 6.2% difference which you will feel.    Gear ratios are just math.
  • Wiz636
Posted December 18, 2015 - 08:07 PM
Whenever I want to gear up for some more open and fast riding I leave the rear sprocket alone and throw on a 14t front sprocket. Lot's easier and cheaper.  That's roughly equivalent to dropping 4 teeth off the rear sprocket.
  • Racinkc1
Posted December 19, 2015 - 12:33 PM
good to know guys. 4 teeth is a little much, but its cool to know that ratio. I figured 1 tooth wouldnt be noticable.....
Posted December 20, 2015 - 08:36 AM
More like 3 teeth, actually.
49/13= 3.77:1
46/13= 3.53:1
49/14= 3.50:1
I used to switch between a 14 and 15 front on my '03 all the time.
