02 WR426 Flooding Carb Issue
4 replies to this topic
  • robmx57
Posted December 16, 2015 - 09:31 AM
Hello all!
          My neighbor has recently picked up an 02 WR426 that did not run.  We cleaned the carb and it ran good for a few seconds then just died.  We took it back off couldnt find anything wrong, put it back on and now its like the float is getting stuck open.  we hooked it up with the bowl off and manually moved the float, and the gas shuts off.  I am kind of lost as to what it could be.  Whatever it is, it is causing a lot of gas to flood the cylinder.  Any help would be greatly aprreciated!!
  • madriders86
Posted December 16, 2015 - 11:11 AM
Sounds like maybe the float height is wrong. Did you measure it?
  • Krannie McKranface
Posted December 16, 2015 - 11:21 AM
Pull the float needle and inspect the tip for grooves: replace it
Inspect the cavity it sits in for corrosion: polish it and the needle body
Re-set your float height
  • robmx57
Posted December 16, 2015 - 11:31 AM
Not quite sure where at on the float to measure from...  Should it just be level with the bowl sealing surface?  Or is there an actual measurement you need to hold?
Thanks again!
Posted December 16, 2015 - 11:37 AM
Thanks again!
A service manual is your friend
Download it from Yamaha's site
