Preload-Adjuster YZ450F '14
11 replies to this topic
  • lhf
Posted December 14, 2015 - 10:35 AM
There are only a few things that could be made better on my 450f so i just want to share what i have done.
A year ago i started to design an alternative prelod adjuster because i did not want to hammer on my shock.
I coose the KTM-design to adapt to the YAMAHA shock dimensions.
I fabricated two examples from billet aluminium on my mill for testing.
Then have one anodized and assembled one to my shock. After one year of using it i can say that its working very well. Of course it is not orange!
It took me many hours of milling and i can say that its not always funny to make them by hand.
If somebody has a CNC-machine workshop, it should be a lot easier. If somebody is interested to build one or more, i would share the CAD-File. It ist generated in FreeCAD. Exporting Step-files ist possible.
Maybe you could make one or two for me?
lhf #56
Posted December 14, 2015 - 10:43 AM
Nice.  I prefer the X-Trig adjuster.
http://www.xtrig.com...d-Adjuster.html
  • GHILL28
Posted December 14, 2015 - 10:47 AM
Very cool.  What's the thread on the ID?
I would also love to run the X-Trig on my '14, but I don't know if it will have access with the IMS tank on there.  If anyone knows for sure if it will or not, please share.
  • lhf
Posted December 14, 2015 - 11:13 AM
the thread is a M60x1.5 mm.
lhf #56
  • demonspeed24
Posted March 23, 2016 - 08:01 PM
Hi! Very nice collar! I plan to build one for my yz250 2t 2008. The threads is the same so your model is very interesting!  :goofy: Can you share the dimension/ plan for it? CAD-File? I have some threads broken on my shock so I need something larger than the stock one! Thank's!
  • Sheriff245
Posted March 24, 2016 - 02:05 AM
The shock body is not the same diameter on the 450. This part won't work on your bike. You would have to alter the design to make it fit.
  • demonspeed24
Posted March 24, 2016 - 08:07 AM
The thread patern on my yz250 08 shock is m60x1.5 too. i cant understand how it could't fit...?
  • Sheriff245
Posted March 24, 2016 - 03:30 PM
The shock body is not the same diameter.
  • demonspeed24
Posted March 24, 2016 - 03:57 PM
What is the diameter of both, the 450 2014 and the 250 2008? I dont say that I dont belive you but if you say that they are not the same diameter you probably know both diameter? It will be helpfull too to find something that could fit! :)
  • GHILL28
Posted March 24, 2016 - 04:14 PM
ID on the new 450 is 50mm.  ID on your shock is 46mm.
The two shocks require two different springs - the older spring will NOT fit on the newer shock body/spring seat.  Can reasonably assume the nominal diameter of the threads differ as well.  I would guess they kept the wall the same and it's an M56 x 1.5.  That's a GUESS remember.
  • demonspeed24
Posted March 24, 2016 - 08:04 PM
Thank's for the info! ;) anyone can confirm? I'll note that, m56x1.5 for the 450 or the 250 2t?
  • GHILL28
Posted March 24, 2016 - 11:14 PM
That is a GUESS based on a standard wall thickness, and it is for the 2T.  Someone else will have to measure and verify that.
The 450 is definitely an M60 x 1.5
