Dirt and water passed the air filter screen 2014 YZ450
10 replies to this topic
  • mxvet137
Posted December 13, 2015 - 04:17 PM
After washing my bike with the Twinair air filter cover in place, a little water made it passed the Twinair cover into the intake. I shined a flashlight into to intake and noticed that tiny granules of dirt also passed through the screen into the intake. I service my air filter after every ride and even use a small amount of Notoil grease to seal the filter. I'm pissed. This shouldn't be happening. I guess I need to take off the intake and clean it out. Anyone experience this on 2014-2106 YZ450's? Suggestions? Thanks. Dave
Posted December 13, 2015 - 06:52 PM
Pressure washer?
  • mxvet137
Posted December 13, 2015 - 10:45 PM
Pressure washer?
No, but the pressure from my hose with a nozzle is really strong. I have the Cycra Powerflow Shroud kit and the filter and air box gets really dirty after 1 ride. I started using the Twinair cover to clean that area when I washed the bike. I can't understand how dirt made it past my filter and through the screen. It's just tiny little particles of dirt, but still.
  • Ctown208
Posted December 13, 2015 - 11:18 PM
Just pull the intake and the throttle body off then you can rest at peace. That's my opinion only takes 15 mins to strip it and handle the issue
  • GHILL28
Posted December 14, 2015 - 10:51 AM
You have to let the whole area around the filter cover dry before putting the foam on there.  If there's still water there, it will go through/under the foam.  The angle of the airbox opening doesn't help this.
I usually leave the airbox cover on there overnight while I'm cleaning/oiling the air filter, just so there's no water present both on the filter, and on the airbox.
  • mxvet137
Posted December 14, 2015 - 11:00 AM
Sounds like good advice. Thanks!
  • mxvet137
Posted December 14, 2015 - 11:04 AM
There was no water prior to putting on the Twinair cover. I just carefully pulled off the air filter, cleaned the area where is seats with contact cleaner, then put on the Twinair cover nice and tight. I washed the bike and used a towel and compressed air to blow off everything. The next day I went to prep it and pulled the cover off and found that water had penetrated the cover. Not a lot but enough to concern me. Thats when I noticed that a tiny bit of dirt had made it passed the screen into the intake, which really concerned me. Thanks.
  • GHILL28
Posted December 14, 2015 - 11:06 AM
If you used an aerosol contact cleaner, that may have blown debris into the boot?  Doesn't explain the water however.
Posted December 14, 2015 - 11:14 AM
Ease up on the water pressure while washing the area.  Even a high pressure nozzle on a garden hose can drive water under stuff like an air box cover, and dirt with it.  Pressure washers can actually shove water past a gasket.  A "shower head" style spray is much more advisable.
  • mxvet137
Posted December 15, 2015 - 03:54 PM
No, I wouldn't do that. :) I sprayed it on a paper towel and wiped it down. Thx
  • mxvet137
Posted December 15, 2015 - 03:56 PM
That's what I thought. I've seen Factory mechanics using the Twinair air box cover and a pressure washer, so I thought it would be okay. Guess not.
  • Hot  50 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • 10 replies
