2007 yz450 popping
16 replies to this topic
  • 88motoman88
Posted December 13, 2015 - 10:51 AM
Runs great but pops quite a bit. Starts not to bad. Stock jets. Stock bike really, well weisco piston, hot rod crank. Stock exhaust. I dont know where the fuel screw is. Seems like the idle screw makes little difference in the idle. I do have a ket kit for it with a 160 m amd 45 pilot. What should i do to start?
  • 88motoman88
Posted December 13, 2015 - 12:23 PM
I just took my jets out and they are already 45 pilot. And 160 main. What should i look at now. Fuel screw?
  • stevethe
Posted December 14, 2015 - 01:38 AM
If it's poping on decel it's pretty normal.
  • 88motoman88
Posted December 14, 2015 - 04:28 AM
Im the only guy really when i go riding. It must be running rich or lean or something, prob an adjustment
  • Krannie McKranface
Posted December 14, 2015 - 06:08 AM
Service the carb
http://www.dirtrider...r_carb_rebuild/
Put on a remote fuel screw and learn how to use it
Posted December 14, 2015 - 07:07 AM
If it was me, I'd check the exhaust for leaks before I screwed around with the carburetor.
  • 88motoman88
Posted December 14, 2015 - 11:14 AM
I did repack the muffler. Where would it leak? The connection at the head and the connection where the pipes connect?
  • RockerYZWR
Posted December 14, 2015 - 11:27 AM
Yep.
  • 88motoman88
Posted December 15, 2015 - 04:25 AM
Ok ill check for leaks. Is it possible when i repacked the pipe i have a leak there? Also i checked the fuel screw and it was one and a quarter turns out. Could that be the problem? I thought it was suppose to be 2 ish roughly with my jets 160 m an 45pilot. Im at sea level
Posted December 15, 2015 - 07:30 AM
... i checked the fuel screw and it was one and a quarter turns out. Could that be the problem? I thought it was suppose to be 2 ish roughly with my jets 160 m an 45pilot. Im at sea level
should be closer to two.
http://www.thumperta...ircuit-setting/
  • 88motoman88
Posted December 20, 2015 - 05:04 AM
So i cleaned the pilot and main jet and adjusted tje fuel screw to 1 3/4 turns. Almost no popping now but when i wemt ro start it i smelt gas and had to push start it to get it running. After riding for awhile ot did start again woth like 4 kicks. Is it to rich. Ive never smelt gas
  • 88motoman88
Posted December 20, 2015 - 05:06 AM
The idle is def still hanging though. I read that is from a lean condition and i meant to say 1 and 1/2 turns out
Posted December 20, 2015 - 08:38 AM
Check your valve clearance.
Posted December 20, 2015 - 06:22 PM
hot start
fuel screw oring
header crush washer
loose boots
worn out slide plate seal
  • 88motoman88
Posted December 26, 2015 - 02:19 PM
Gray i checked the valves the intake were .10mm and the exhaust .20. Should i move on the fuel screw setting again?
  • 88motoman88
Posted December 26, 2015 - 02:29 PM
Seems like the hot start plastic screw into the top of the carb is tight, header is tight with a new crush washer installed at rebuild. I didnt take it off but it seems tight with no leak, boots seem tight and in place. Stupid question but is one turn on thw fuel screw a 360 or 180 degree turn?
Posted December 27, 2015 - 06:20 PM
180 is obviously half of one turn
  • 10 replies
  • Hot  30 replies
  • Hot  113 replies
  • On January 15, 2017
  • Hot  47 replies
