  • Instagram
IMS Tank for the 2016 WR450
  • Please sign in to reply
24 replies to this topic
  • stevethe
Posted December 08, 2015 - 02:04 PM
I just called them and they said they have a 3.0 gal. tank available.
  • patrick2wd
Posted December 09, 2015 - 05:44 AM
(this thread is worthless without pictures)
  • Ghazzah
Posted February 29, 2016 - 10:19 AM
Hi Team.
I've ordered a 2016 WR450F and am gathering fargles and bling in anticipation of its arrival.
Will be using the bike for extended enduro riding and am concerned about fuel range. A recent article quoted 50 miles (80kms) on a tank. One of my local loops is 100 miles (160kms).
Looking hard at the IMS 3 gallon (11.3 litre) tank for extended range.
http://www.ebay.com/...tlWn8ML&vxp=mtr
Has anyone fitted one yet? Any mods necessary? Black or Natural?
Feedback/pics please.
Gaz.
  • 450crazy
Posted February 29, 2016 - 12:59 PM
I just installed the IMS tank 3.0gal on my 2015 WR450F... Fit great easy install no problems. Now trying to figure out if it is designed to run without the battery. It seems they redesigned them to be able to but cant find verification.
  • Monk
Posted February 29, 2016 - 01:02 PM
I havent seen a 3.0g for the FX/WR that doesn't have the shrouds incorporated.
If anyone was serious, I would gladly send my IMS tank YZF to soemone and let them try and retrofit it...
  • stevethe
Posted February 29, 2016 - 02:16 PM
Nice offer Mr. Monk. But so far as I can tell your YZ tank won't fit the 16 WR, FX models. I had a talk with IMS and they confirmed the battery and the electronics on the inner rear fender will be in the way.
Supposedly the uglier larger IMS tank is a bolt on to the WR and FX models. Acerbis is supposed to be coming out with a little larger tank for the 250 model and it may be a bolt on.
I am getting about 33 miles with about a half gallon of gas left. However with the type of full throttle hill climbing and nasty trails it's pretty good milage.
My old CR500 use to have to use an extra .8 gal tank to do the same riding.
  • Monk
Posted February 29, 2016 - 02:20 PM
I wonder if it could be done. Smaller battery under the skidplate or such...
  • stevethe
Posted February 29, 2016 - 02:43 PM
It would be nice. However there is a lot of wiring under there. I am using the smaller battery it could be relocated under the side plate possibly. IMS thought it would be too much trouble and scraped the idea.
The YZ tank also has a different fuel pump that has a side outlet and no provision for the fuel light.
  • JDLowrance
Posted February 29, 2016 - 06:05 PM
This is less than ideal...do not like the shroud tank....looks like shit (IMHO). Hopefully one of the other tank manufacturers come up with a better solution.
  • 450crazy
Posted March 01, 2016 - 04:52 AM
3.0 gallon tank
  • JDLowrance
Posted March 01, 2016 - 05:17 AM
3.0 gallon tank
That's a 12-15 IMS tank.....completely different to the 2016.
  • 450crazy
Posted March 01, 2016 - 07:02 AM
Yep 16 is totally different. Thought for sure it was same tank
Edited by 450crazy, March 01, 2016 - 10:09 AM.
  • 450crazy
Posted March 01, 2016 - 10:06 AM
That sucks. Hope you find a tank sinner than later
Edited by 450crazy, March 01, 2016 - 10:11 AM.
  • Ghazzah
Posted March 01, 2016 - 10:31 AM
Thx, Team.
I gather that the IMS tank fo the 16WR requires the side shrouds/fairings to be removed? If so, Fugly! Anyone got pics of this installed?
G.
  • Ghazzah
Posted March 01, 2016 - 10:53 AM
Hmmmmm. Functional, yes. Pretty, nope.
  • Monk
Posted March 01, 2016 - 10:56 AM
Might put some additional weight on the front end making for some better traction though...
  • stevethe
Posted March 01, 2016 - 11:46 AM
It needs some graphics real bad.
  • JDLowrance
Posted March 02, 2016 - 05:34 AM
Problem is graphics do not last long on plastic fuel tanks.....historically. Maybe graphic tech has gotten better in the last decade or so (haven't used them since 2003).
  • stevethe
Posted March 02, 2016 - 05:59 AM
They actually work pretty well. As long as you don't put fuel in the tank. :goofy: :goofy: :goofy:
  • Macsplace
Posted March 02, 2016 - 11:47 AM
Another choice would be this 15L tank Safari designed for the 2015 WR250f that should work on the 2016 450. Only thing is it looks like a nightmare changing the air filter.
Edited by Macsplace, March 02, 2016 - 12:58 PM.
