Changing oil
3 replies to this topic
  • oranj
Posted December 06, 2015 - 07:35 PM
I just picked up a 2011 YZ450F today and the previous owner stated I would need to loosen a bleeder bolt located on the side of the engine on the kickstart side of the bike. The bike did not come with a manual and I did some searches on this forum and you tube but found nothing about this "bleeder screw". I did see there were two drain bolts and the bike takes a full court of oil. I just wanna make sure I don't mess the engine up by doing something wrong. Any help would be appreciated. This is my first four stroke bike since I was a kid on a XR75. Thanks in advance.
  • Krannie McKranface
Posted December 06, 2015 - 09:05 PM
He is referring to the 'oil check bolt' on the side of the motor; some use it to verify the oil quantity in the motor.
You are better off to measure the oil you add, every time.
  • Slow and Jerky
Posted December 07, 2015 - 04:10 AM
You should be able to download a manual here:
http://www.yamaha-mo...uals/index.aspx
  • oranj
Posted December 09, 2015 - 05:41 AM
Thank you both for the information.
  • Hot  47 replies
  • Hot  36 replies
  • 9 replies
  • Hot  50 replies
  • 0 replies
