Re degree your can to yz spec
Engine Power Up Kits Hot Cams Stage 1 Inlet & Stage 2 Exhaust
31 replies to this topic
  • avlisj
Posted December 06, 2015 - 10:40 AM
Someone just mentioned the re degree of their stock wr cam to yz spec. I did search this and was thoroughly confused due to too many years of bikes mentioned. Then full cam swaps etc. I am only interested in info for the FI model bikes and the rotation of stock exhaust cam to yz timing. Where is the performance gain? Engine brake effect? Gas mileage? Do you have to grind the decompression pin? Anybody who's done this please chime in.
Edited by avlisj, December 06, 2015 - 10:41 AM.
  • KennyMc
Posted December 06, 2015 - 12:05 PM
You will always have to deal with the decomp pin if you want to retain the e-start, that's a given.
  • Krannie McKranface
Posted December 06, 2015 - 04:41 PM
You rotate the 2006 or '07 EX cam one tooth, then grind the decomp pin so it is approx 1.125mm shorter.
The grind is unfortunately, a trial and error thing, becaue the pins are not precision (not all the exact same length).
So, you have to temp assemble the EX cam and cap and test the decomp system by hand, and re-grind till you are successful.
'06 has a small midrange hit, and the '07 has no hit with a power band that start right at idle.
FI and carb heads are the same.
Edited by KRANNIE, December 06, 2015 - 04:41 PM.
  • avlisj
Posted December 06, 2015 - 05:06 PM
So it's not as simple as just rotAte my existing stock exhaust cam one tooth during my next valve check to get the mod? A 2014 WR.
Posted December 06, 2015 - 05:29 PM
No it is not.
You don't have that option anymore.
  • avlisj
Posted December 06, 2015 - 05:37 PM
You think it's worth the hassle, now that with the FI bikes I have infinite ways to adjust the hit or power delivery by changing the map?
  • stevethe
Posted December 06, 2015 - 05:49 PM
Ignition and cam timing are two different things.
  • avlisj
Posted December 06, 2015 - 06:02 PM
Feels the same on the bike
Posted December 06, 2015 - 06:27 PM
Sorry, but you do not have the ability for 'infinite ways to adjust hit or power  delivery' with FI and IGN mapping.
FI changes fuel/air ratios, and nothing more. It is not a 'booster' or a 'hp' option.
If it is way off (like stock) it will make it run better and faster when you change the map.....but that's it.
IGN timing changes mostly makes for changes in throttle response at specific rpms and throttle openings.
You can make the throttle openings more or less repsonsive, lwith better acceleration, and that's about it.
If you want more power, you need to get more fuel in and out of the head, via cams, porting, pipes.....and THEN you change the mapping to match.
  • avlisj
Posted December 06, 2015 - 06:42 PM
Disagree
When riding, real world test, I can change mapping to have hit at bottom or smooth pull throughout etc. thus infinite ways to adjust hit.
Not talking about increasing HP numbers seen on a dyno.
  • chu
Posted December 06, 2015 - 07:44 PM
It will never really be YZ spec because there's not as much lift or duration.
  • KennyMc
Posted December 06, 2015 - 08:29 PM
No it is not.
Couldn't he just rotate it? No more e-start but if he's not concerned with that, so be it.
  • stevethe
Posted December 06, 2015 - 08:37 PM
I hear the YZ cam isn't much different just different lobe centers.
  • Bass Mechanic
Posted December 06, 2015 - 09:30 PM
when my cam was re degreed the tech pressed the gear off the cam and pressed it back on in a new location. it was not simply moved a tooth on the sprocket.
i cannot comment on the pin and the decompressor. but i know it starts every bit as good as it originally did.
  • stevethe
Posted December 07, 2015 - 05:15 AM
Your guy likley retarded the exhaust cam toward the YZ spec. It would be interesting to know if he ground the pin.
The 12' fuel injected bikes and the 07-11 use the same cam.
Edited by stevethe, December 07, 2015 - 05:16 AM.
  • Bass Mechanic
Posted December 07, 2015 - 05:28 AM
In my case the bike picked up about 10-13 Hp across the rom range mostly in the mid to upper rpm.
The low end increased slightly but the peak Hp was 53 hp at the wheel on the dyno.
Also I have the FMF slip on and the comp ecu.
The ignition timing and fuel were tweaked for maximum hp and I had the tuner also create a fuel efficient map which I have never used. The bike gets around 40 mpg on the trails we ride.
Also the bike is for sale as I have a 450 fx on order should be coming any day now. If your interested send me a PM without delay!
The bike is on Craig's list in Colorado Springs colorado and I have an interested buyer but he has not actually had time to see it yet.
  • avlisj
Posted December 07, 2015 - 07:56 AM
I'll buy the exhaust cam off you. Haha.
What did that mod do to engine braking ?
Can you post that fuel efficient map created buy a TUNER for the rest of us?
Edited by avlisj, December 07, 2015 - 07:58 AM.
  • Bass Mechanic
Posted December 07, 2015 - 08:12 AM
sorry returned the bike to stock exhaust and the cam stays with the bike.
engine braking seems unaffected, I would guess if anything it is probably better than stock. certainly no worse.
heres the ad if anyone is interested.
http://cosprings.cra...5319029312.html
Edited by Bass Mechanic, December 07, 2015 - 08:14 AM.
  • stevethe
Posted December 07, 2015 - 08:30 AM
Hum 10-13 hp is really not doable for a pipe and a cam change.
Carbed bikes don't give up hp and a 08 YZ450 on a Dyno jet made 49+ hp.
Maybe a funny Dyno.
Edited by stevethe, December 07, 2015 - 08:31 AM.
Posted December 07, 2015 - 12:37 PM
From stock corked-up, maybe.....
