WR 400 hesitation
5 replies to this topic
  • Rocketvet
Posted March 01, 2004 - 11:28 AM
I have a 2000 WR 400 and have recently done an exhaust insert change, air box mod, and grey wire disconnect. The bike always tended to "stumble" from idle to about 1/8 throttle and it hasn't really changed with the mods. Any jetting or carb mods that would remove this annoyance?
  • MonK_E
Posted March 01, 2004 - 01:03 PM
welcome to TT.
if you have done the air box and exhaust mods re jetting will be necessary. :)
  • Hick
Posted March 01, 2004 - 01:56 PM
Do a search on this term: "BK Mod"
You may also consider a wholesale re-jetting now that it is uncorked/uncovered.
Hope this helps.
  • Rocketvet
Posted March 02, 2004 - 11:04 AM
Someone else I exchanged an e-mail with suggested adjusting the pilot screw and checking the pilot jet since the problem seems to be from idle to about 1/8 throttle. Anyone have any experience with this?
  • faggio40
Posted March 02, 2004 - 11:37 AM
It isn't simple to suggest you some "universal advices" to help you: It's correct to adjust pilot screw and pilot jet, but how many you have to modify these set up it's depend from the mods that you have done.
bye
  • Hick
Posted March 02, 2004 - 02:07 PM
You're going to have to bite the bullet and learn to jet the bike. It is easy, the bike is talking, you just need to listen.
So it has a stumble at about 1/8th. Hmm. What to do.
How about a long cruise in a tall gear at the same throttle position? That eliminates the effect of the accelerator pump. If the bike surges during this test try a richer setting, if it stumbles try leaner. Get it as good as you can. If it is really 1/8th throttle then the pilot screw should affect things, a good rule of thumb is that if you end up richer than 2-1/4 turns out, or leaner than 1-1/2 turns out you may want to try another pilot jet.
Now, once you have a steady-state situation worked out, if the stumble is still there when you twist it (likely) then you need to adjust your accelerator pump w/ the BK mod.
Hope this helps.
