2010-13 yz450f forks..on a 2015?
9 replies to this topic
  • Justin89
Posted November 28, 2015 - 09:10 PM
Will 2010-2013 front forks only work on a 2015 yz450f? Searched and couldnt find the answer. Also checked with the Jedi master himself but want to quadruple check. Thanks.
  • Krannie McKranface
Posted November 28, 2015 - 09:18 PM
I do believe they are all exactly the same
  • Justin89
Posted November 28, 2015 - 09:28 PM
Awesome. I shouldnt have a problem mounting my 2015 front wheel to the forks correct? I just have a chance at some factory A kit front forks off of a 2013, hence the reason for wondering. Thank you for your response.
Posted November 28, 2015 - 09:32 PM
A kit forks are not necessarily 'standard' sized forks.
There are many KYB bottom lug possibilities, lengths, etc.
Verify dimensions.
Handling changes can be made with different lug types, so look closely.
If the front wheel that mated to the fork was an OEM wheel or a OEM fit aftermarket hub and wheel, then you at least know the wheel and caliper will fit without issues.
  • Justin89
Posted November 28, 2015 - 09:35 PM
Verify dimensions.
Copy, thank you. The forks are standard size and dimensions, mounted on a display (otherwise stock) 2013 yz450f. Stock triple clamps, stock excel wheels, etc. The forks are kashima coated, DLC coated, subtanks, etc. I guess not technically A-kit like a Pro Circuit set up. Thank you for your help!!
  • Monk
Posted November 28, 2015 - 09:37 PM
No, 14-current run a 22mm front axel over the 13-older 20mm axel. There are also changes that don't necessarily affect the swap but might become apparent when riding... Valving, spring rates, fork rigidity...
  • Justin89
Posted December 03, 2015 - 07:59 AM
So i believe i could use 13' wheel bearings and a 13' front axel and be good to go correct? I actually have those parts in my shop. Friend has the suspension and is practically giving it to me so i wanna at least attempt it. Anyone have thoughts?
  • Monk
Posted December 03, 2015 - 08:17 AM
Unfortunately, you'll need to find a bearing with the 22mm inner diameter that will fit an older hub. The outer diameter of a 22mm bearing is slightly larger and made for the larger 14+ hub. I have not found this size bearing as I have a few older front YZ hubs.
You will also need the 22mm spacers...
  • Monk
Posted December 03, 2015 - 08:21 AM
Keep in mind 13 forks are shorter then 14 forks too. I think your getting caught up in the nostalgia of these forks. Consider that you might have to get them revalved, re-sprung etc etc along with the current chassis changes, you could be putting a lot of time and effort into setting up the bike... And because your asking here, I'm gonna guess you don't have the most experience...
  • Justin89
Posted December 03, 2015 - 02:43 PM
Thanks for your insight.
  • 9 replies
  • Hot  36 replies
  • Hot  28 replies
