High idle when in gear and clutch pressed
4 replies to this topic
  • Prob1em
Posted November 22, 2015 - 11:23 PM
Is this normal?
Bike is 03 YZ450...
Thanks
Posted November 23, 2015 - 07:01 AM
Higher than in neutral? Check your valve clearance and your pilot screw adjustment, check for air leaks.
  • Prob1em
Posted November 23, 2015 - 11:20 AM
Yes, higher than in neutral. Valve clearance is good, engine was rebuilt. No air leaks. Carburetor was cleaned recently, and pilot adjusted. Strange is that this happens only when in gear, and clutch pressed. :confused:
Posted November 23, 2015 - 01:40 PM
Not that strange.  In gear, the timing is different than in neutral because there's no signal from the neutral switch (in neutral, the CDI retards the timing and lowers the rev limit.
A significant speed difference generally happens when something causes a lean idle condition.
  • Prob1em
Posted November 23, 2015 - 11:07 PM
I will take apart my varb again, and look at pilot jet. Maybe it's clogged again :o
Thanks
Edited by Prob1em, November 23, 2015 - 11:07 PM.
  • 9 replies
  • Hot  33 replies
  • 5 replies
Motocross
  • Hot  491 replies
