Wr426 idle issues
2 replies to this topic
  • masdomonkey
Posted November 21, 2015 - 04:01 PM
I just cleaned the carb, choke it on first few kicks, it starts but cant stay started, I gave it gas once and i got it to run, but i let off and it died
  • Krannie McKranface
Posted November 21, 2015 - 04:18 PM
You pilot jet or the passage above it, is clogged or partially clogged.
What does ' I just cleaned the carb' actually  mean..... because a carb that old really needs to be rebuilt......
http://www.dirtrider...r_carb_rebuild/
  • masdomonkey
Posted November 22, 2015 - 01:56 PM
Its cool i got it to run now, where the boot connects there were two small jets my guess is for air flow on the idle but i cleaned them and it started up nice. The only thing im worried about is when i was starting it ( this never happend to me yet) the compression felt really low like i could kick it without the comp release, it started really low rpm but i remember seeing this plug that goes on the carb, so i thought maybe it was that telling the cdi to open it or something i dont know , but that was with no choke, then i started it with choke and fiddled with the idle and it kicked normal after that when i started it again (needing the comp release to kick the fu&king thing)
