  • Instagram
Related Reviews
Yamaha YZ450F 2004
Last review by 1trackmind
Yamaha YZ450F 2008
Last review by thaoe_thumper
No reviews available
Be the first to review this
Yamaha YZ450F 2011
Last review by Le_Racer
Yamaha YZ450F 2003
Last review by Garrett Canada
Related Garage
Yamaha YZ450F (2004)
Owner: 1trackmind
Added on November 29, 2016
2014-2016 yamaha yz450f cornering/turning
  • Please sign in to reply
31 replies to this topic
  • Edge316
Posted November 15, 2015 - 11:21 PM
So I just picked up a 2016 yz450f today and I'm seeing that people are still having issues with the cornering/turning on this generation of bike. I haven't had a chance to ride the bike and will not be riding it until next weekend so I can't give my review yet but I'm hoping I made the right choice. Now with that being said, are most of you guys happy with the overall cornering characteristics or are most of you having to mess with lowering links, triple clamps, lowered shocks, lowered radiators, engine relocation kits,etc to get this generation 2014-2016 bike to corner correctly ?
  • dj78
Posted November 16, 2015 - 12:37 AM
No need for extra parts, just balance fork height and sag right and you are good to go.
Older models you could use longer link to get better balance.
  • Edge316
Posted November 16, 2015 - 05:08 PM
Thanks for responding dj78, I called Drd racing to see what they recommend and they said they are running the 22mm triple clamps and radiator lowering kit. They also recommended the engine relocation kit but said it is not a necessity like on the 2010-2013. They do not use a lowering link. I'm going mess with the fork height and sag and go from there.
  • Mxrider637
Posted March 29, 2016 - 02:13 PM
Hi
I'm sure by now you must have lots of hours on your 2016 yz450f I'm getting mine end of week or first of next week
Wondering how it handles and have u found a good set up for the forks and sag
  • Edge316
Posted March 29, 2016 - 06:40 PM
Yea I have a few hours on the bike now. I replaced the front tire with a Dunlop Mx32 and I had Enzo revalve the suspension. I kept the stock springs for my weight, and had Enzo install a 2.5mm spacer in the shock which lowered the rear by approximately 7mm. From what I've been told running a spacer in the shock is similar to running a longer suspension linkage. I've been told many other suspension companies are recommending the spacer. Now with that being said I noticed a definite improvement in cornering since the revalve. It sticks much better at the entrance of corners than when it was stock. It still isn't the best cornering bike I've ever owned and I definitely wouldn't consider it a front steering bike but I'm not fighting it like when it was stock. I'm alot happier with the cornering and over all handling of the bike. Now even though its improved I might still try a 22mm clamp, mainly because we have two yz250fs and they both use the 22mm clamp and I can pull the clamps off of one of them to try it. I'm also going to buy the drd radiator lowering kit, not sure if I'll ever try the drd relocation kit. If your on the fence about buying a 16 yz450f don't worry its an awesome bike. Yea it took alittle dialing in for me but everyone's different.
Edited by Edge316, March 29, 2016 - 06:41 PM.
  • Edge316
Posted March 29, 2016 - 06:52 PM
Let me also add that I slid the forks up 5mm and the sag is currently at 105 which is what Enzo recommended. I'm going to try playing with the sag somemore.
  • Edge316
Posted April 02, 2016 - 08:15 PM
Actually Enzo recommended 102mm sag not 105mm.
  • Brainguy
Posted April 11, 2016 - 10:23 AM
I found that the sag was best set at 95mm and the forks raised 6mm in the triple.  A set of MX32's and the biuke turned like my 250.
  • Costa Rican YZ450F
Posted April 11, 2016 - 10:58 AM
I'm by no means a suspension guy, but I've toyed around with my '16 YZ450F and find it to work best with me at 95mm and Forks showing 4mm to the cap.
  • Edge316
Posted April 11, 2016 - 02:27 PM
I've been thinking of trying less sag. I had it at one point at 100mm before the revalve but since I've had the suspension revalved I've had it between 102- 105, but haven't gone back the other way. I'll try less sag next time I take it out.
Edited by Edge316, April 11, 2016 - 02:59 PM.
  • jrusher
Posted April 11, 2016 - 09:48 PM
I picked up a left over 15 , pulled forks up 6 mm, sag is at 105 , I cut subframe down  and lowered seat height about 15mm , turns like my 15 yz250f , power is crazy put a softer map in really happy with bike
  • Cyclemedic
Posted April 11, 2016 - 09:57 PM
My 14 450F turns almost as good as my YZ125! I have it set up with the PC lowering link, 105mm of sag and forks at the OEM Height. I also when to a 6.3 rear spring with the OEM fork springs ( I weight 225 lbs). I have no problems turning the bike in the tightest of inside lines. I notice no Yamaha front end push like my 2008 YZ450 had. Something to consider, is the bike is heavy and produces a very torquey bottom end hit which could lead to the front end feeling light and vague. I run a smoother map on the motor as well and I think that helps a lot! Overall, in my opinion, it's one of the best 450s out. Excellent suspension, fast RELIABLE motor, and it handles great ( straight line stability and cornering).
  • Crusty Cy
Posted April 14, 2016 - 04:02 PM
Springs for your weight, correct sag, and a Bridgestone X30 front tire. Love this bike. Much better than the 10-13, which I had no issues with.
  • Crusty Cy
Posted April 14, 2016 - 04:06 PM
...oh... And the 22mm triple clamp. Or 21mm if you have the cash.
  • hondaman331
    Hasta la vista
Posted August 29, 2016 - 06:31 AM
2016 here, sag at 100 and forks in Stock position, have zero issue turning bike.
  • Krannie McKranface
Posted August 29, 2016 - 06:53 AM
105/25 sag, stock fork height.
Very ballanced.
100/21 sag, stock fork height; a bit more oversteer and harsher forks on off road terrain.
Posted August 29, 2016 - 08:51 AM
Very ballanced.
The YZ450FX has different basic geometry than does the YZ450.
Posted August 29, 2016 - 11:52 AM
We are told the frame and suspension lengths and travel are the same....so how does it differ...
  • Edge316
Posted August 29, 2016 - 01:26 PM
From what I can tell the two bikes are nearly identical. The triple clamp offsets are the biggest difference , the fx overall length is slightly shorter, and the fx has a lower seat height....that's the only difference.
Posted August 29, 2016 - 01:29 PM
The FX uses the WR frame and different triples.  The differences are minor to the eye, but either bike is exceptionally sensitive to small changes, the YZ/F in particular.
