Anyone pick up a 450FX yet?
951 replies to this topic
Posted March 31, 2016 - 10:54 AM
It's a discussion forum, not a third grade playground.
  • BolinJrsPit Crew
Posted April 02, 2016 - 10:13 AM
I for one would never put a 12 tooth on my fx. The thing is a handful with stock gearing off idle in slippery/ grabby conditions. Almost looped it twice, it happens so fast. Faster than my clutch finger anyways.
I don't have a problem stalling either so.........
Edited by BolinJrsPit Crew, April 02, 2016 - 10:16 AM.
  • Krannie McKranface
Posted April 02, 2016 - 10:38 AM
Yeah but everyone knows that gearing it down makes it less jerky and less likely to loop  :facepalm:
  • MidlifeCrisisGuy
Posted April 02, 2016 - 12:45 PM
We've done it on 2 FI YZ450Fs and I've run a 12 tooth on my WR with a YZ exhaust cam and various maps with no problems.   Throttle control, clutch control, move your weight forward, no problem.   If looping is a problem on a FI YZ450F, change the map.  That is why Yamaha makes a programmer.  I trust both of you have tested this ?
One of our newbie riders looped his WR450F several times, but that was a case of too much bike for a newbie, not anything else.  He would have looped or stalled with 13 tooth as well.  Weight too far back, whiskey throttle, bad result.
The 12 tooth does make it way smoother, assuming you know how to be smooth with the throttle.  If you are jerky with the throttle it won't matter if you have a 12 or a 13 tooth on it, it will launch.  With the 12 tooth you can take it down to idle and tractor along in the technical stuff.  When it opens up, grab 2nd gear if you are worried about looping.
The YZFX and YZF engines are the same except for tuning.   There is a reason the FX has the low first gear gearing it does.  I've yet to read a single magazine complain that 1st was too low or that the bike was uncontrollable with it.
I just did a bunch of winter riding with my WR in all kinds of conditions, including getting caught in the first snow ride without studded tires.  Including riding in spring thaws with mud on ice and thawed wet grass and icy logs.  Never looped once. Guys who rode my bike commented how controllable it was.  Not a single person called it loopy.  Most of this was on the stock map.
Don't knock it until you try it.
Edited by MidlifeCrisisGuy, April 02, 2016 - 12:57 PM.
Posted April 02, 2016 - 01:01 PM
Right
Posted April 03, 2016 - 10:36 AM
Spare me.  The FX flywheel has at least twice the inertia mass of the YZ.
  • KennyMc
Posted April 03, 2016 - 04:38 PM
Well, besides that :D
  • cowboyona426
Posted April 04, 2016 - 10:16 AM
Are any of you FX owners putting an hour meter on the bike, or just using the tuner to read the engine hours?  I like the idea of a stand-alone meter for ease of reading.
Posted April 04, 2016 - 12:09 PM
Peg height
I've measured the AL framed WR's, and the new 'flipped head' WR and FX, and it seems the pegs are 1.25" higher off the ground on the new bikes (accounting for static sag at 0")
That seems insanely high....
  • blbills
Posted April 04, 2016 - 01:01 PM
I can vouch that the peg height is roughly one inch higher than the older WR's.
  • motocrotts
Posted April 04, 2016 - 01:09 PM
Yes, got a Pro taper hour meter on mine.  Wireless to boot.
  • NW_drZ
Posted April 04, 2016 - 03:25 PM
Peg height
The whole new generation WR / YZFX is much bigger everywhere than the previous generation WR's and YZ's.  When i went from my 11 WR to my FX,  I couldn't believe how much taller and bigger the bike felt overall.  Not surprised about the peg height.  Ground clearance is taller as well.
Posted April 04, 2016 - 04:49 PM
Yeah, unless i can alter this, it's a deal breaker for me.
I can't bend my right knee that much to even ride it....
  • NW_drZ
Posted April 04, 2016 - 06:37 PM
Sorry to hear that man. Hopefully there is a way to set it up for you as these generation yamahas are dialed in. Especially the FX models. I know their are companies making offset foot pegs (DRC to name one), but I doubt it's an inch drop. I know you just got that 430rr (I was looking at the 350rr hard before getting my 250FX), are you considering the 450FX?. Are you happy with the 430? Seems like a great bike. Sorry if you already answered this in the Beta sub forum.
Posted April 04, 2016 - 06:48 PM
Yes, very happy with the 430RR.
Very civilized, or agressive if you want.
Incredibly good handling; the best handling dirtbike that I can remember...
Not quite enough brute force for Desert or speed, however.
I have a YZ'd WR now that needs to go,  and I've had track bikes in the past, but the e-start is now a must have.
Yeah, the DRC is only 5mm of drop
SystemTec used to make a 20mm drop bracket, but nothing for the '14+ framed bikes....
Fastway pegs are a 15mm drop.
Can anyone take a couple pics for me?
Right side, peg mounting bracket visible
Left side, peg mounting bracket visible.
Can't seem to find anything close enough on the web.
Want to see why SystemTec said it wasn't possible to make a lower bracket, in our conversation...
  • RMK800
Posted April 04, 2016 - 07:33 PM
Does this help.
  • RMK800
Posted April 04, 2016 - 07:37 PM
  • mobgma
Posted April 04, 2016 - 07:47 PM
What plastic covers are those RMK?
  • RMK800
Posted April 04, 2016 - 07:49 PM
acerbis, but they don't fit right on the clutch side.
Edited by RMK800, April 04, 2016 - 07:51 PM.
  • stevethe
Posted April 04, 2016 - 07:53 PM
One of the problems I had with my 16 WR450 foot pegs that I gather are the same as the fx is they are heavily tilted up on the ends. Making it very hard to ride the bike. It took a lot of grinding to get them next to flat. That also lowered them.
  • Hot  113 replies
  • 9 replies
  • On January 15, 2017
  • Hot  50 replies
