Needle Valve Seat - 08YZ450f
2 replies to this topic
  • yz_ripper
Posted November 12, 2015 - 01:37 PM
Hey guys, i have gas leaking out from the bottom of the bowl hose. 100% sure that its the o-ring on the needle valve seat, before i attempt to pull it out as i might mess it up seat in doing so, i am searching for a replacement valve seat but am coming up with no luck. I called local yamaha dealer but because there is no part # they cant help. I've emailed over 10 sellers on ebay but each one does not have the seat as part of the kit.
where can i find the seat??
Thanks!
Posted November 12, 2015 - 02:28 PM
That is because along about '04 or '05, the needle seat became a press fit, non-serviceable part.  (wasn't my idea)  There is no O-ring, and they do not generally leak there.  You can test by plugging the needle socket with some appropriate small rubber plug and connecting the carb to a fuel line.
More often, it's the needle that leaks, or occasionally a defective or binding float.
  • Krannie McKranface
Posted November 12, 2015 - 05:36 PM
JD Jetting sells a replacment seat kit.
You need a small slide hammer to get out the old one
Motocross
  • Hot  491 replies
  • Hot  50 replies
  • 10 replies
