Bike won't idle
15 replies to this topic
  • 412MotoRob
Posted November 09, 2015 - 01:16 PM
Okay so I was out on my 2005 yz450f yesterday with my buddy and his cousin came out on a quad & while going down a steep hill she rear ended me :) & my handle bars nearly went inside my thigh & missed my sack by like 2 inches. She was okay & her quad was fine & so was I for the most part & I thought my bike was okay as well. Upon starting it back up it backfired like crazy all the way back to my truck & so now it won't idle at all. It idles fine with the choke on & I even tried messing with the idle knob on the side of the carb (the big black knob) & this did almost nothing either way I went. The bike almost died instantly with the choke off almost like a kill switch. The idle knob adjusted fine while the choke was on but I'm not gonna ride around with ma dam choke on.. I know it's not a clogged jet because it's a 2 month old jet & I was running fresh gas & the bike was taken out both days prior to wrecking. What's the deal?
  • CRFRida1605
Posted November 09, 2015 - 01:22 PM
It sounds like the timing may have been thrown off when she hit the rear wheel. Were you stopped when it happened?
I have 0 experience with those twin cam bikes though, its just a guess but I would check the timing and, again this is coming from my knowledge of Hondas, make sure the gear didnt slip on the cam.
  • 412MotoRob
Posted November 09, 2015 - 01:29 PM
I said I was going down a hill & I wasn't going all that fast & I don't understand how my timing could have been thrown off? This has to do with my choke?
  • CRFRida1605
Posted November 09, 2015 - 01:37 PM
Because when she hit you your rear wheel suddenly stopped moving, even briefly. Ill admit it seems strange that it would affect the timing but it sounds like when a single cam bike is off a tooth. How would the choke have been affected by this at all? You said it runs better with it on so it must be working, it only does one thing so its all or nothing really.
  • 412MotoRob
Posted November 09, 2015 - 01:44 PM
I understand where you're coming from but timing has to do with ignition if I'm correct & when the bike should fire & this all ties in with the cdi box. If I put the choke on I can ride around like a happy camper & you wouldn't notice anything about the way it sounds or rides, but I'm not gonna ride around with my choke on :) my point is that if my timing was off it would run like Sh!t whether the choke was on or off....
  • William1
Posted November 09, 2015 - 01:46 PM
Check the hot start
Confirm the throttle cables are not damaged.
Confirm the throttle wheel touches the idle stop screw.
  • 412MotoRob
Posted November 09, 2015 - 01:51 PM
Check the hot start
my hot start cable is loose and the lever doesn't fully go back into place but I don't think it ever really did because I never use the hot start but I'm thinking it might be that..maybe...& how do I check the throttle wheel touching the idle stop screw? The throttle cable itself seems fine.
Posted November 09, 2015 - 01:53 PM
Timing has to do with the cams as well as ignition, but I think it may be more likely that with the crash, something floated free in the fuel and blocked your pilot jet.  It is possible that the abrupt stall caused it to skip a tooth, especially if the cam chain is anything other than totally free-moving and free of stiff links.  The only way for the ignition timing to be off is for the flywheel key to have sheared, and while that is a possibility, it doesn't happen often.
  • 412MotoRob
Posted November 09, 2015 - 01:57 PM
why does the bike run completely fine with the choke on? & I forget to mention I hurried up and hit the kill switch right after I went down. I don't believe my rear tire ever locked up she just hit me enough to knock me over. If anything with timing was off wouldn't it still run like crap with the choke on? Is there anyway this could be a warped head or something?
Edited by 412MotoRob, November 09, 2015 - 01:58 PM.
Posted November 09, 2015 - 02:03 PM
It runs OK with the choke on because the choke is making up for the fact that the pilot jet is blocked.
  • 412MotoRob
Posted November 09, 2015 - 02:08 PM
thanks grey I guess maybe that could be it, just seems unlikely because it's a relatively new jet & I had fresh high octane gas..I guess I'll check the hot start as well
Posted November 09, 2015 - 02:50 PM
As far as the hot start is concerned, you could also have pulled the cable housing up out of one of its seats in a lever or adjuster along the way, which could be keeping it open.
  • Decreasing Dave
Posted November 10, 2015 - 07:56 PM
Did you check to see if the exhaust was bent?
Posted November 11, 2015 - 07:08 AM
Why would that be important?
  • Brandon7711
Posted November 11, 2015 - 07:18 AM
I would open the carb first before I went messing with all this other stuff. Sometimes it's not even related and it's just something you overlook
  • 2banga
Posted November 11, 2015 - 06:52 PM
Did you pull the carb and float bowl and clean it when you changed the jet?
  • 0 replies
  • Hot  38 replies
  • Hot  30 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • Hot  50 replies
