Radiator Guards 2014 WR450
11 replies to this topic
  • nd4spdbh
Posted November 09, 2015 - 12:02 PM
Alright guys,
What radiator guards / braces do you prefer?
I had some works connection braces on my 250X and never had an issue with bent rads.... 2nd ride out on the new 450F and i drop her at 2mph and the clutch side rad got all bent (fml)
So what ones do you guys like?
Also would i be able to use an IMS bigger tank and the works connection braces?
  • Dualsportwr450
Posted November 09, 2015 - 12:18 PM
I ha e the unabikers on my 2012 and I have the force on my 08. I'd say hands doe the force radiator guards for the Yamaha is hands down better. I have desert tanks on both bikes. Had to manipulate the fit for the unabikers. I say force radiator cages
https://forceaccesso...adiator-guards/
  • nd4spdbh
Posted November 09, 2015 - 12:59 PM
^ none of those say they will fit the newer fuel injected 2012-2015 WR450.... also those look real restrictive.
  • Krannie McKranface
Posted November 09, 2015 - 01:20 PM
Mohard
  • drdanbozeman
Posted November 09, 2015 - 06:20 PM
I have a 2012 WR450 with unabiker radiator guards and IMS 3 gal tank - totally compatible. I really don't see how you could bend the unabiker guards, they are really well built and the mounting is strong.
  • AtomicGeo
Posted November 09, 2015 - 06:21 PM
I have the unabiker blue colored ones on my 2014 with the IMS 3.1 gal tank.  They fit well.
Edited by AtomicGeo, November 09, 2015 - 06:22 PM.
  • Dualsportwr450
Posted November 09, 2015 - 06:36 PM
Not restrictive I have desert tanks on both bikes and the 2012 is fuel injected, I ride in the desert when it's 100 degrees and have never over heated, works connection are crap. And you described you have a Honda??? Yamaha doesn't make an X model. Are you putting them on a Honda
  • 5270ADVRIDER
Posted November 09, 2015 - 06:55 PM
I have Devol guards on my 2013 WR450F with an IMS 3.0 gal. Tank. I like Devol because they protect the front of the radiators also.
  • Andrew Puetz
Posted November 10, 2015 - 04:57 AM
GYTR braces on 12 WR, no issues.  unsure on IMS tank fit though
  • nd4spdbh
Posted November 25, 2015 - 10:44 AM
I ended up scoring on some moose radiator guards. I like the design of them as they are a full cage around the rad vs just a brace. and from the looks of it they shouldnt be a problem with an IMS tank.
  • motoxer667
Posted December 29, 2015 - 02:08 AM
I had GYTR on my '12 with an IMS tank. Ended up bending both radiators in separate crashes about a year apart with the GYTR's. The second crash twisted and pushed the radiator back into the ignition coil. I have since replaced the radiators with a pair from Myler's Radiator and put Enduro Engineering braces on it. No issues as of now, but I haven't crashed much either since
  • guru
Posted December 29, 2015 - 09:47 AM
+1 on the UniBiker and 3.0 IMS tank. Great fit on a 13 and hella tough! Much easier to install before you bend the rads.
