5th gear stuffed 1999 yz400f
11 replies to this topic
  • Yz400fthrashr
Posted November 07, 2015 - 09:11 PM
Runs fine in all gears but when you click it into fifth its like it neutralises,guessing the 5th gear pinion is stripped,any ideas?
And how much would it cost to get fixed and will it affect the motor when its ridden or will it be okay till it's fixed?
  • WALKINGWOUNDED
Posted November 07, 2015 - 09:30 PM
Sounds like it may be the slider for 5th gear.
You may want to take a look at the shifter mechanism behind the side cover first, but you will likely be splitting the case.
For more exposure, post this in the relevant Yamaha forum too.
  • WALKINGWOUNDED
Posted November 07, 2015 - 09:32 PM
If it's a 4-stroke, and the transmission and engine share the same oil, it could do some engine damage if there is schrapnel floating around in there from the 5th gear failure.
  • Yz400fthrashr
Posted November 07, 2015 - 10:05 PM
Thanks mate,when i gave it an oil change couldnt see any shrapnel in the oil,there was a small amount in the oil filter which i changed and did a full oil change,yes its a 4 stroke
It runs fine so it musn't of done any or much damage hey
Cheers mate
  • WALKINGWOUNDED
Posted November 07, 2015 - 10:11 PM
Your filter may very well catch any debris that may be floating around in there, but not sure if I would want to risk it.
I know the urge to ride is strong, but I wouldn't want to replace the crank too.
  • Yz400fthrashr
Posted November 07, 2015 - 10:22 PM
Yeah thats true hey wouldnt want that happening thats for sure,would you have any idea how much it would cost to fix man
  • WALKINGWOUNDED
Posted November 08, 2015 - 07:04 AM
A 5th gear, a slider and gaskets are probably not that expensive, but it will be time consuming to split the case.
Look on TT's parts catalog page, and get some prices.
  • Yz400fthrashr
Posted November 18, 2015 - 06:01 AM
Have any idea how much it would cost in parts and labour at a shop? Can do the basics but not experienced enough for doing that i don't think
  • WALKINGWOUNDED
Posted November 18, 2015 - 06:36 AM
I do all of my own work, so not sure what it would cost.
I'll talk to a friend of mine who has an Mx shop, and get an ideal.
I'll post the info this evening.
  • Yz400fthrashr
Posted November 18, 2015 - 12:52 PM
Cheers bro much appreciated
  • WALKINGWOUNDED
Posted November 18, 2015 - 05:02 PM
Spoke with local indendepend Mx shop.
To pull the motor, split the case, replace 5th gear as needed, reassemble, and install motor, labor only is $550.00
Add in parts and the possibility of finding more issues, it could be costly.
You may consider finding another bike to ride, and use this one to learn on.
  • WALKINGWOUNDED
Posted November 18, 2015 - 05:06 PM
Just realized your in Oz.
Not sure of the hourly labor rates down under, but could still be potentially costly.
  • Hot  113 replies
  • 10 replies
  • Hot  47 replies
  • 5 replies
