WR Compression Lock w/ E-Button
6 replies to this topic
  • Dube2
Posted November 03, 2015 - 08:28 AM
So why do I get a compression lock when using the e-button. Not all the time. When this hapends, the starter will not turn it over. Then I need to kick it till it passes the locking part and she usually fires right up. She runs fine. Even on cold starts, it usually fires up pretty easy. Could it be out of adjustment timing chain? It's usually only on a warm bike.
  • woods-rider
Posted November 03, 2015 - 08:42 AM
When the bike stops right at TDC it takes more compression to get it out of TDC. Happens to all of them.
  • Dube2
Posted November 03, 2015 - 09:03 AM
ok, sounds like nothing to worry about. Like I said, she runs fine. Thanks WR
  • Krannie McKranface
Posted November 03, 2015 - 10:16 AM
You have to roll it in gear to get over the hump
  • Dube2
Posted November 03, 2015 - 02:17 PM
yea, I usually give it a few light kicks to make sure I don't break anything.
  • 2banga
Posted November 03, 2015 - 03:27 PM
Putting it in gear and rolling backwards a little is much easier on the kick start mechanism.
  • avlisj
Posted November 05, 2015 - 04:49 PM
This brings up a question i always had. Is it bad to have your motor turn backwards. As in backing down a hill you stalled on and you drop the clutch but are in too high a gear for compression to stop the bike. Too high a gear being the reason you didnt make the hill in the first place. of course.
