Cheap Supermoto Brake Setup?
2 replies to this topic
  • Thumperist
Posted November 01, 2015 - 08:52 PM
Hey guys, I am looking to convert a WR450F into a supermoto, and I'm wondering what brake setup I can get on the cheap. I heard that you can use the master cylinder and calipers off of a 06 SXV 550 and it will work fine on the WR450F. Wondering if anyone knows of something cheaper/potentially better.
If anyone has any experience doing the supermoto conversion on the WR450F, please chime in. What brake caliper/master cylinder did you get? Do you have the part numbers? How are the brakes? Etc... Thanks in advance!
  • kurtcrf450
Posted November 01, 2015 - 09:19 PM
I did a yz450f. For street stock brakes worked with no issue on warp 9 wheels and rotors. The track they failed for me pretty quick and I bought a full setup after. Run it a little and see if you notice any brake fade and if you do then upgrade.
Obviously an oversized thicker rotor with a bigger caliper will perform better all around than the smaller stock ones but for basic street stuff you don't need the performance gains
  • patrick2wd
Posted November 02, 2015 - 10:23 PM
Ape RXV... I had one...
Imo its the otger way around..
You can use the caliperbracket of a yz/wrf 320 disk for the ape..
Thats how I did it...
But still needed quite some alterations...
