Cold Starting Problem
23 replies to this topic
  • Krannie McKranface
Posted November 04, 2015 - 02:43 PM
#21
I dont even know what the ACV is, I will have to look in shop manual and see.
Pilot jet is stock
What about the TPS?.....could that be fouling things up?
Yes,  but no.
It's just a map chaning feature.
Posted November 04, 2015 - 02:45 PM
#22
Pilot jet is stock
MAIN:  170  (165 is stock)
NEEDLE: JD Blue Needle, 3rd from top position
Pilot Jet 48 (45 is stock)
Pilot Air Jet (stock 80)  <<<<< 70 is stock....80 makes it lean, so you need a 48 to compensate....
Starter Jet: (stock 65)
Leak Jet (stock 50)
Air screw 2 1/2 turns
  • bobpara
Posted December 11, 2015 - 06:23 AM
#23
Just as a follow up to this thread, I was having a problem cold starting the bike after it sat for more than a week
If not, everything is fine
So I go to cold start the thing and get frustrated.
I twist the throttle 5 or 10 times (accel pump) AND I carck or start to open the throttle as I poke the starter lever, and Boom! It starts maybe second or third poke on the lady button
Could my idle be set too low and its messing up starting?
Posted December 11, 2015 - 06:46 AM
#24
Pretty normal for under 50 degrees.
You can change your starter jet to a larger size, but then it will be too rich in the summer.
