05 WR revival build.
30 replies to this topic
  • Spam16v
Posted December 31, 2015 - 05:13 AM
#21
No, but full blown pneumonia sure did on top of the holidays...
  • Spam16v
Posted February 24, 2016 - 04:52 PM
#22
ImageUploadedByThumper Talk1456361465.268500.jpg ImageUploadedByThumper Talk1456361481.326821.jpg
Should be ready to run. Need to play with some wiring. Doing headlight, tail light and brake light off the rear brake with a TrailTech KTM setup.
  • Spam16v
Posted February 29, 2016 - 04:51 PM
#23
Well it runs, noise on the right side of the engine... Going to do a water pump seal kit and hunt for it and recheck the valves. Hope the rod didn't get hurt the last time the top end failed on this crank. Didn't feel any play. Got a spare loose crank I can get a rod kit slammed into and welded easily enough. We'll see. Oh and BTW f-you Electrosport for selling garbage merchandise.
  • steggat
Posted March 05, 2016 - 10:09 AM
#24
Mmm might be wrong but i think you piston is not in the right way
  • zibbit u2
Posted March 05, 2016 - 12:53 PM
#25
No.. you're 100% right.  That piston is 180 deg out.  Should be like this:
  • steggat
Posted March 05, 2016 - 01:25 PM
#26
So that could be your noise my friend
  • still2smokin
Posted March 05, 2016 - 06:42 PM
#27
Interference fit motor with a piston 180 deg out cannot be a good combination :eek:  :eek:  :eek: .
  • Spam16v
Posted March 08, 2016 - 04:43 AM
#28
Best news I've heard all day. It runs (shocked after this revelation) but has a noise... Going to order a top end gasket kit and flip it around...
  • zibbit u2
Posted March 08, 2016 - 08:34 AM
#29
check the valves when you've got it apart and make sure they're all straight.
  • steggat
Posted March 20, 2016 - 04:41 AM
#30
Problems solved ?
  • Spam16v
Posted April 03, 2016 - 03:37 AM
#31
Reused gaskets, flipped the piston around and slammed it together. Once the carb settled down (had it upside down) it fires off instantly.
