426 rear brake on 400 swing arm?
2 replies to this topic
  • Islay426
Posted October 29, 2015 - 08:26 AM
does anyone know if the yz 426 rear break will fit on the 400 swing arm, there slightly different in shape and the caliper carrier is a bit different. would save me a lot of hassle of someone new.
Posted October 29, 2015 - 12:15 PM
The only thing I can see that would prevent it from working would be if you have a '98 YZ400, which would have a 20mm rear axle, rather than a 22.  Otherwise, if the caliper bracket fits the anchor slot in the swing arm, and the axle lines up, it should work OK.
  • Islay426
Posted October 30, 2015 - 12:32 AM
well it's a '99 so guessing it should be OK to use. will give it a try at some point. thanks!
