New sprockets, new chain?
6 replies to this topic
  • Thumperist
Posted October 27, 2015 - 10:34 PM
Hello all, I am thinking about running 16/44 for sprocket size on some supermoto wheels and I am wondering if you need to get another chain... I will be converting a 03 WR450f into a supermoto and just wondering if I can just use the chain the comes on it or if I need a new one. Thanks in advance!
Also, does anyone know where to get a 16 tooth front sprocket? How will I be able to tell if it fits? For example, will this one fit??
http://www.amazon.co...front sprocket#
  • seer
Posted October 28, 2015 - 03:13 AM
A 15 is a tight fit on most bikes. I believe there's a SM section here
  • seer
Posted October 28, 2015 - 03:15 AM
A 15 is a tight fit on most bikes. I believe there's a SM section here. If 16/44 does fit I'd expect a very gappy tranny on a wr.
  • Krannie McKranface
Posted October 28, 2015 - 05:07 AM
http://www.thumperta...m/27-supermoto/
  • Thumperist
Posted October 28, 2015 - 05:24 AM
Hello all, I am looking to convert a WR450f into a supermoto. I will be running 16/44 sprockets on there and I'm wondering if this swap requires a new chain, please let me know!! Thanks in advance!
  • stevethe
Posted October 28, 2015 - 06:03 AM
I believe a 16 will barley fit however your gearing will be a bit too tall. I run 15-43 if you want taller gearing you might try 15-41 or 42. I'm not 100% sure if the transmission ratio's are the same as I have a 08.
  • stevethe
Posted October 28, 2015 - 06:37 AM
Normally you always put a new chain on new sprockets.
