Damn stumped on this yz450
Yamaha YZ450F
30 replies to this topic
  • jackiefresh69
Posted October 25, 2015 - 11:20 PM
Hello guys . I have a newly purchased yz450f 2008 model and I bought it knowing that it wasn't quite running right. It does seem to start but it will not stay running very long. I can keep it running if I keep it revving but choke on or off it refuses to stay running. Things I've tried are:
Turned idle up but it will still stall out after a while.
Adjusted feul screw
Swapped pilot jet with a new one
Cleaned carby various times (thoroughly)
Checked slide wasn't it wrong way
Adjusted and checked valves are in spec
It will run sometimes well for say a minute or so then just die like someone hit the kill switch.
What direction should I head now? Thanks guys
  • bradgross71
Posted October 26, 2015 - 04:32 AM
When the bike is stone cold and you start it will it run longer than after a few starts?
  • Krannie McKranface
Posted October 26, 2015 - 05:09 AM
You have either fuel starvation or spark loss I would say
First things first:
- no idle means a bad pilot circuit. You may have changed the pilot jet, but you need to ream the passage above it with fishing line and spray cleaner. There is an elbow up there that clogs
- no idle can also mean a contaminated stator pick up, though usually this shows up at higher rpms.
- no idle can also mean an upside down slide plate, which should have the hole on the bottom
You say if acts like a kill switch after a minute or so. Will it re-start immediately, or do you have to 'wait' a bit?
Does it run 'cleanly' at other rpms, no backfiring ?
Do you have a gas tank vent valve on the hose? If so remove it.
Have you changed the plug?  Cleaned and checked the electrical connections, especially the coil ground, plug cap, and main ground ?
Posted October 26, 2015 - 08:56 AM
Check the stator physically to be sure that it's bolted down to the cover securely, and that none of the coils appear loose on the coil frame.  Then check the resistances per the manual.  Assuming that you have pilot circuit passages cleared (verify by blowing carb cleaner up into it and watching for it to exit into the crab throat just to the engine side of the slide), that would be the next place to look.
  • jackiefresh69
Posted October 26, 2015 - 01:06 PM
First things first:
Thanks for the help I will check these things today. With the restartin it's pretty unpredictable . Sometimes it will start right up but then it won't run longer than 5 seconds this time. Yes runs great if you keep it revving. A little backfire but nothing real crazy. I'll get back tonight with what else I've tried
Okay thanks I will check today
Yes it does seem to be that way
  • kawasaki_873
Posted October 26, 2015 - 02:45 PM
make sure the hot start plunger is not sticking/seized.
Posted October 26, 2015 - 02:54 PM
...or that there's no free play, or the cable housing isn't up out of one of its seats.  (good call)
  • jackiefresh69
Posted October 26, 2015 - 05:15 PM
Okay so I've taken carb apart again . Slide is in right way. Sprayed through all the passageways and watched the carb clean go all the way through . Hot start is free and All the cables have free play and stator looks good and is secure . Havnt tested it yet though.
Maybe I have a valve leaking? Thanks for the help guys . What else should I try?
  • jackiefresh69
Posted October 26, 2015 - 05:18 PM
I
Edited by jackiefresh69, October 26, 2015 - 05:26 PM.
Posted October 26, 2015 - 06:04 PM
Is the hot start plunger dropping all the way and sealing in it 's chamber ?
  • jackiefresh69
Posted October 26, 2015 - 06:16 PM
Yep hot start all the way in
  • jackiefresh69
Posted October 26, 2015 - 06:47 PM
It really dosnt seem to have a pattern in it starting. Just started then and ran with choke but choke off it stalls and backfires a little . Might have to go up on pilot . Fuel screw at 2.5 out and a 42 pilot. Might have to go to 45? What do you guys think
  • jackiefresh69
Posted October 26, 2015 - 06:50 PM
[quote name="jackiefresh69" post="12712570" timestamp="1445914060"]It really dosnt seem to have a pattern in it starting. Just started then and ran with choke but choke off it stalls and backfires a little . Might have to go up on pilot . Fuel screw at 2.5 out and a 42 pilot. Might have to go to 45? What do you guys think[/quote
Now it runs without choke. can't get any sort of pattern. Either way it will run but soon die out? Has spark but seems kind of weak
Edited by jackiefresh69, October 26, 2015 - 06:51 PM.
Posted October 26, 2015 - 07:17 PM
Your info is starting to be contradictory
You should use a 45 pilot
If it runs rough past idle, it's not  the pilot jet
If it cannot reach higher rpms, it sounds like the stator or a mis-timed cam or cam timing jump
  • jackiefresh69
Posted October 26, 2015 - 07:31 PM
It basically won't idle at all . But if I keep revving it it's goes fine . I just can't let it idle or else it will die out
  • jackiefresh69
Posted October 26, 2015 - 11:33 PM
Could a valve be leaking causing this problem?
  • pomoco
Posted October 27, 2015 - 02:47 AM
Do a leakdown test. Check timing. Install an automotive spark tester. It is basically a plugwire with a light built in. You'll be able to see the strength of the spark and if it is eratic or going away.
  • moto867
Posted October 27, 2015 - 04:17 AM
Have you checked to see if the valves are tight?
  • jackiefresh69
Posted October 27, 2015 - 01:54 PM
Yep I just adjusted the valves so there all in spec .
Okay cool thanks I'll look into both
  • moto867
Posted October 27, 2015 - 01:55 PM
How tight were they?
