Can anyone help?
2 replies to this topic
  • michaelribar
Posted February 28, 2004 - 12:05 PM
I have a 2001 WR 426fn that spits out oil from the breather tube. After 2-3hrs of riding it will spit out as much as a quart of oil. It holds 2.3 quarts total. Does any one know what my problem is before I rip my bike completely apart? Should I be worried?
Thanks
  • Rich_in_Orlando
Posted February 28, 2004 - 12:53 PM
You're overfilling the oil. You say yours holds 2.3 quarts-the manual for my bike says it takes 1.6 quarts of oil after an oil change. My '99 and your '01 aren't that different.
When I change the oil in my bike, I measure out the exact amount of oil the manual says to with a Ratio-Rite. Then I run the bike for 3-5 minutes before checking the dipstick. Sometimes after only a couple of minutes of running it still is only about halfway up the dipstick. But run it for a few more minutes and it shows full. When I have accidentally overfilled it, it spits out oil in much larger quantities. There's the quart of oil it spits out.
  • sdcrooks
Posted February 28, 2004 - 03:19 PM
My "01" calls for 1.6 QTS. This is directly from the manual. I've never had a problem with oil blowing out the breather tube. You must overfilling
